When installing the python requirements for the NVIDIA Caffe package there is an error on the leveldb package:
sudo pip install -r python/requirements.txt
In file included from ./leveldb/port/port_posix.h:50:0,
from ./leveldb/port/port.h:14,
from ./leveldb/db/filename.h:14,
from leveldb/db/builder.cc:7:
./leveldb/port/atomic_pointer.h:212:2: error: #error Please implement AtomicPointer for this platform.
error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
DIGITS isn’t intended to be installed on Jetson or officially supported on ARM. The setup directions indicate to install DIGITS on the host (x86_64). Please follow the System Setup directions from the tutorial to configure DIGITS on the host (i.e. you will also need to install CUDA Toolkit, NVIDIA driver, cuDNN, and NVcaffe for DIGITS). See this diagram illustrating the DIGITS workflow (i.e. train with DIGITS and deploying inference on Jetson):
As dusty_nv has already replied, NVIDIA DIGITS does not officially support the Jetson TX2 platform. So you’d be on your own if you’d like to get that to work.
