Hi Wayne, thanks for all of the help. I can see the Ethernet as enP2p1s0 in ip addr now. I believe this is healthy:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: mgbe0_0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1466 qdisc mq state DOWN group default qlen 1000
link/ether [MAC-MASKED] brd ff:ff:ff:ff:ff:ff
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
4: can1: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
5: mgbe1_0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1466 qdisc mq state DOWN group default qlen 1000
6: can2: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
7: can3: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
8: mgbe2_0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1466 qdisc mq state DOWN group default qlen 1000
9: mgbe3_0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1466 qdisc mq state DOWN group default qlen 1000
10: enP2p1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
inet [IPv4-MASKED]/22 brd [IPv4-BROADCAST-MASKED] scope global dynamic noprefixroute enP2p1s0
valid_lft 12885sec preferred_lft 12885sec
inet6 [IPv6-MASKED]/64 scope global temporary dynamic
valid_lft 604697sec preferred_lft 85786sec
inet6 [IPv6-MASKED]/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 2591900sec preferred_lft 604700sec
valid_lft 469sec preferred_lft 469sec
inet6 fe80::[LINK-LOCAL-MASKED]/64 scope link noprefixroute
11: wlP1p1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
12: l4tbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
inet [IPv4-MASKED]/24 scope global l4tbr0
inet6 fe80::1/64 scope link tentative
13: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN group default qlen 1000
14: usb1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN group default qlen 1000
15: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
Unfortunately, I changed two things to get it to work. I used the sdk manager instead of a usb thumb drive and I also updated to 38.2.1. I am not sure which properly fixed it. The power cycling is still happening although it is not a huge issue.
