Issues regarding Jetson system and JetPack customization/trimming
The current JetPack packages are very large, resulting in a massive system image. Does NVIDIA provide any official guidance on slimming down JetPack and the system itself?
This would enable faster system startup and allow the system to run on hardware with limited storage capacity.
This might be a start.
https://docs.nvidia.com/jetson/archives/r39.2/DeveloperGuide/SD/RootFileSystem.html#basic-flavor-root-file-system
As whitesscott suggests, please check developer guide to customize Ubuntu rootfs. May also try Yocto rootfs:
Making sure you're not a bot!
ok thanks
