Issues Regarding the USB Type-C Mode of Jetson Thor
If the 3rd USB port is modified to host-only mode , then when using l4t_initrd_flash.sh for flashing, this Type-C port needs to function as a peripheral —which will result in a flashing failure.
Yes, that is expected. That port needs to be in otg or device mode to at least support device mode.
Does Thor not support USB OTG mode currently? Is there any plan to fix it in the future?
Are you talking about an issue on NV devkit or your custom board?
The case is totally different
The phenomenon is the same on the devkit and the custom board.
No, the case is different.
NV devkit known issue is coming from the Cypress PD controller on it which causes OTG not work.
If your custom board is not using Cypress PD controller then it has nothing to do with Devkit case.
OTG is supported already. It is just not working with Cypress PD.
