So, i was try to run the deepstream container, having this error
docker run --gpus all -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepst
ream/deepstream-5.0 nvcr.io/nvidia/deepstream:5.0-dp-20.04-triton
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container pr
ocess caused “process_linux.go:449: container init caused “process_linux.go:432: running prestart hook 0 ca
used \“error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: mount error: file creati
on failed: /var/lib/docker/overlay2/35b2ed80985f81e2e2a6a0703b0a3b4c687b1e77fccba7d6605f77f402556078/merged/
usr/lib/x86_64-linux-gnu/libcuda.so.1: file exists\\n\”””: unknown.
I also tried to install the necessary drivers and tried to run a sample deepstream app, most of the time resulted in a segmentation fault, or this error:
/deepstream-image-decode-app …/…/…/…/samples/streams/sample_720p.mjpeg ─╯
WARNING: Overriding infer-config batch-size (2) with number of sources (1)
Now playing: …/…/…/…/samples/streams/sample_720p.mjpeg,
Running…
ERROR from element nvv4l2-decoder: Could not open device ‘/dev/nvhost-nvdec’ for reading and writing.
Error details: v4l2_calls.c(656): gst_v4l2_open (): /GstPipeline:dstest-image-decode-pipeline/GstBin:source-bin-00/nvv4l2decoder:nvv4l2-decoder:
system error: No such file or directory
Returned, stopping playback
Deleting pipeline
here is the driver and runtime details
╰─ deepstream-app --version-all ─╯
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 11.1
CUDA Runtime Version: 10.2
TensorRT Version: 7.1
cuDNN Version: 8.0
libNVWarp360 Version: 2.0.1d3
and yes the sample docker container for tensorflow works as followed from this tutorial: https://docs.nvidia.com/cuda/wsl-user-guide/index.html
