Hi all,
I’m using Jetson TX2 module and L4T r32.3.1 kernel and have an issue when capturing two camera
streams from single source which is connected to CSI-A/CSI-B ports, using 4 data lanes and one clock
lane. The camera source is connected using CSI_A_CLK lane and two data lanes of the CSI-A port and
two data lanes of the CSI-B port (CSI_A_D0/CSI_A_D1 and CSI_B_D0/CSI_B_D1). Since only one clock lane is connected, I have to use virtual channels to capture two different camera streams.
The first stream is using CSI2 virtual channel 0 (VC0), the second stream uses CSI2 virtual
channel 1 (VC1). If only one camera (VC0 stream) is connected and the media pipeline links are
initialized properly, I can capture the VC0 camera data using v4l2-ctl.
But if both cameras are connected and media pipeline is initialized, I can only successfully capture
VC1 stream. When VC0 capturing is started, I get “PXL_SOF syncpt timeout” errors.
Any idea what might be wrong here? Or has anyone a suggestion how to debug this issue?
Below is the dmesg output and trace buffer dump taken after interruption of the
hanging command “v4l2-ctl -d /dev/video0 --stream-mmap --stream-count=3” for capturing VC0 stream:
[ 3225.197599] nvcsi 150c0000.nvcsi: settle time reading from props
[ 3225.197622] nvcsi 150c0000.nvcsi: csi_port: 0
[ 3225.197863] nvcsi 150c0000.nvcsi: settle time reading from props
[ 3225.197880] nvcsi 150c0000.nvcsi: csi_port: 0
[ 3225.198220] tegra_channel_g_selection: irs10x0c 8-003d
[ 3225.205285] tegra-vi4 15700000.vi: Create Surface with imgW=224, imgH=172, memFmt=32
[ 3225.207806] nvcsi 150c0000.nvcsi: csi4_start_streaming port_idx=0, lanes=4
[ 3225.207826] nvcsi 150c0000.nvcsi: csi4_stream_init
[ 3225.207854] nvcsi 150c0000.nvcsi: csi4_stream_config
[ 3225.207879] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
[ 3225.207895] nvcsi 150c0000.nvcsi: settle time reading from props
[ 3225.207913] nvcsi 150c0000.nvcsi: discontinuous_clk = 0 reading from props
[ 3225.207927] nvcsi 150c0000.nvcsi: settle time reading from props
[ 3225.207940] nvcsi 150c0000.nvcsi: csi4_phy_config
[ 3225.207958] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
[ 3225.207983] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 400
[ 3225.207997] nvcsi 150c0000.nvcsi: cil_settingtime was autocalculated
[ 3225.208013] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 20
[ 3225.409455] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 3225.415900] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 3225.416449] nvcsi 150c0000.nvcsi: csi4_stop_streaming port_idx=0, lanes=4
[ 3225.416469] nvcsi 150c0000.nvcsi: settle time reading from props
[ 3225.416486] nvcsi 150c0000.nvcsi: discontinuous_clk = 0 reading from props
[ 3225.416502] nvcsi 150c0000.nvcsi: settle time reading from props
[ 3225.416515] nvcsi 150c0000.nvcsi: csi4_phy_config
[ 3225.416534] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000004
[ 3225.416557] nvcsi 150c0000.nvcsi: csi4_stream_check_status
[ 3225.416583] nvcsi 150c0000.nvcsi: csi4_cil_check_status 397
[ 3225.416604] nvcsi 150c0000.nvcsi: csi4_start_streaming port_idx=0, lanes=4
[ 3225.416617] nvcsi 150c0000.nvcsi: csi4_stream_init
[ 3225.416643] nvcsi 150c0000.nvcsi: csi4_stream_config
[ 3225.416665] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
[ 3225.416678] nvcsi 150c0000.nvcsi: settle time reading from props
[ 3225.416693] nvcsi 150c0000.nvcsi: discontinuous_clk = 0 reading from props
[ 3225.416705] nvcsi 150c0000.nvcsi: settle time reading from props
[ 3225.416718] nvcsi 150c0000.nvcsi: csi4_phy_config
[ 3225.416734] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000004
[ 3225.416757] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 400
[ 3225.416770] nvcsi 150c0000.nvcsi: cil_settingtime was autocalculated
[ 3225.416786] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 20
[ 3225.417310] tegra-vi4 15700000.vi: Create Surface with imgW=224, imgH=172, memFmt=32
[ 3225.417430] video4linux video0: free_ring_buffers: capture init latency is 215 ms
[ 3225.621463] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Trace dump:
# tracer: nop
# entries-in-buffer/entries-written: 556/556 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-3044 [000] .... 3225.191290: tegra_channel_open: vi-output, irs10x0c 8-003d
v4l2-ctl-3044 [000] .... 3225.192574: tegra_channel_set_power: irs10x0c 8-003d : 0x1
v4l2-ctl-3044 [000] .... 3225.196234: tegra_channel_set_power: 150c0000.nvcsi--6 : 0x1
v4l2-ctl-3044 [000] .... 3225.196242: csi_s_power: enable : 0x1
v4l2-ctl-3044 [005] .... 3225.205229: tegra_channel_capture_setup: vnc_id 0 W 224 H 172 fmt 20
vi-output, irs1-3045 [000] .... 3225.205572: tegra_channel_set_stream: enable : 0x1
vi-output, irs1-3045 [000] .... 3225.207775: tegra_channel_set_stream: 150c0000.nvcsi--6 : 0x1
vi-output, irs1-3045 [000] .... 3225.207782: csi_s_stream: enable : 0x1
vi-output, irs1-3045 [000] .... 3225.208029: tegra_channel_set_stream: irs10x0c 8-003d : 0x1
kworker/3:0-2705 [003] .... 3225.213445: rtos_queue_peek_from_isr_failed: tstamp:101490445711 queue:0x0b4b4500
kworker/3:0-2705 [003] .... 3225.213453: rtcpu_start: tstamp:101490449028
kworker/3:0-2705 [003] .... 3225.213458: rtos_queue_send_from_isr_failed: tstamp:101490463075 queue:0x0b4a7258
kworker/3:0-2705 [003] .... 3225.213461: rtos_queue_send_from_isr_failed: tstamp:101490463183 queue:0x0b4aad68
kworker/3:0-2705 [003] .... 3225.213463: rtos_queue_send_from_isr_failed: tstamp:101490463289 queue:0x0b4ac998
kworker/3:0-2705 [003] .... 3225.213466: rtos_queue_send_from_isr_failed: tstamp:101490463397 queue:0x0b4ae518
kworker/3:0-2705 [003] .... 3225.213468: rtos_queue_send_from_isr_failed: tstamp:101490463502 queue:0x0b4af2d8
kworker/3:0-2705 [003] .... 3225.213470: rtos_queue_send_from_isr_failed: tstamp:101490463607 queue:0x0b4b0098
kworker/3:0-2705 [003] .... 3225.213473: rtos_queue_send_from_isr_failed: tstamp:101490463712 queue:0x0b4b0e58
kworker/3:0-2705 [003] .... 3225.213475: rtos_queue_send_from_isr_failed: tstamp:101490463817 queue:0x0b4b1c18
kworker/3:0-2705 [003] .... 3225.213479: rtos_queue_send_failed: tstamp:101490464251 queue:0x0b4a7258
kworker/3:0-2705 [003] .... 3225.213481: rtos_queue_send_from_isr_failed: tstamp:101490469752 queue:0x0b4a7258
kworker/3:0-2705 [003] .... 3225.213484: rtos_queue_send_from_isr_failed: tstamp:101490469858 queue:0x0b4aad68
kworker/3:0-2705 [003] .... 3225.213486: rtos_queue_send_from_isr_failed: tstamp:101490469965 queue:0x0b4ac998
kworker/3:0-2705 [003] .... 3225.213488: rtos_queue_send_from_isr_failed: tstamp:101490470071 queue:0x0b4ae518
kworker/3:0-2705 [003] .... 3225.213491: rtos_queue_send_from_isr_failed: tstamp:101490470176 queue:0x0b4af2d8
kworker/3:0-2705 [003] .... 3225.213493: rtos_queue_send_from_isr_failed: tstamp:101490470281 queue:0x0b4b0098
kworker/3:0-2705 [003] .... 3225.213495: rtos_queue_send_from_isr_failed: tstamp:101490470386 queue:0x0b4b0e58
kworker/3:0-2705 [003] .... 3225.213498: rtos_queue_send_from_isr_failed: tstamp:101490470494 queue:0x0b4b1c18
kworker/3:0-2705 [003] .... 3225.213500: rtos_queue_send_failed: tstamp:101490471434 queue:0x0b4a7258
kworker/3:0-2705 [003] .... 3225.381428: rtos_queue_peek_from_isr_failed: tstamp:101495446044 queue:0x0b4b4500
vi-output, irs1-3045 [005] .... 3225.417255: tegra_channel_capture_setup: vnc_id 0 W 224 H 172 fmt 20
vi-output, irs1-3045 [005] .... 3225.417451: tegra_channel_capture_frame: sof:-549620691636.-271027366144
kworker/3:0-2705 [003] .... 3225.437411: rtos_queue_send_from_isr_failed: tstamp:101497061196 queue:0x0b4a7258
kworker/3:0-2705 [003] .... 3225.437418: rtos_queue_send_from_isr_failed: tstamp:101497061304 queue:0x0b4aad68
kworker/3:0-2705 [003] .... 3225.437421: rtos_queue_send_from_isr_failed: tstamp:101497061412 queue:0x0b4ac998
kworker/3:0-2705 [003] .... 3225.437423: rtos_queue_send_from_isr_failed: tstamp:101497061518 queue:0x0b4ae518
kworker/3:0-2705 [003] .... 3227.733552: rtos_queue_send_from_isr_failed: tstamp:101568734468 queue:0x0b4b0098
kworker/3:0-2705 [003] .... 3227.733554: rtos_queue_send_from_isr_failed: tstamp:101568734573 queue:0x0b4b0e58
kworker/3:0-2705 [003] .... 3227.733557: rtos_queue_send_from_isr_failed: tstamp:101568734677 queue:0x0b4b1c18
kworker/3:0-2705 [003] .... 3227.733559: rtos_queue_send_failed: tstamp:101568735101 queue:0x0b4a7258
kworker/3:0-2705 [003] .... 3227.789428: rtos_queue_peek_from_isr_failed: tstamp:101570445942 queue:0x0b4b4500
v4l2-ctl-3044 [003] .... 3227.817430: tegra_channel_set_stream: 150c0000.nvcsi--6 : 0x0
v4l2-ctl-3044 [003] .... 3227.817436: csi_s_stream: enable : 0x0
v4l2-ctl-3044 [000] .... 3227.820402: tegra_channel_set_power: irs10x0c 8-003d : 0x0
v4l2-ctl-3044 [000] .... 3227.820418: tegra_channel_set_power: 150c0000.nvcsi--6 : 0x0
v4l2-ctl-3044 [000] .... 3227.820422: csi_s_power: enable : 0x0
Media entity links seem to be correct, here is what I see with media-ctl:
# media-ctl -p
Media controller API version 0.1.0
Media device information
driver tegra-vi4
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 0.0.0
Device topology
- entity 1: 150c0000.nvcsi--6 (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
<- "irs10x0c 8-003d":0 [ENABLED]
pad1: Source
-> "vi-output, irs10x0c 8-003d":0 [ENABLED]
- entity 18: 150c0000.nvcsi--5 (2 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
<- "ov5695d3 8-0049":0 [ENABLED]
pad1: Source
-> "vi-output, ov5695d3 8-0049":0 [ENABLED]
- entity 121: irs10x0c 8-003d (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
[fmt:Y12_1X12/224x172 field:none colorspace:unknown
crop:(0,0)/224x172]
-> "150c0000.nvcsi--6":0 [ENABLED]
- entity 123: vi-output, irs10x0c 8-003d (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "150c0000.nvcsi--6":1 [ENABLED]
- entity 135: ov5695d3 8-0049 (1 pad, 1 link)
device node name /dev/v4l-subdev3
pad0: Source
[fmt:SBGGR10_1X10/2592x1944 field:none colorspace:srgb]
-> "150c0000.nvcsi--5":0 [ENABLED]
- entity 137: vi-output, ov5695d3 8-0049 (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
<- "150c0000.nvcsi--5":1 [ENABLED]
My cameras and NVCSI/VI port description in device-tree looks like:
&vi_base {
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port_0: port@0 {
status = "okay";
reg = <0>;
vi_in_0: endpoint {
status = "okay";
vc-id = <0>;
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&csi_out_0>;
vi_port_1: port@1 {
status = "okay";
reg = <1>;
vi_in_1: endpoint {
status = "okay";
vc-id = <1>;
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&csi_out_1>;
&csi_base {
chan_0: channel@0 {
status = "okay";
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
csi_in_0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&sensor_out_0>;
port@1 {
status = "okay";
reg = <1>;
csi_out_0: endpoint@1 {
status = "okay";
remote-endpoint = <&vi_in_0>;
chan_1: channel@1 {
status = "okay";
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
csi_in_1: endpoint@2 {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&sensor_out_1>;
port@1 {
status = "okay";
reg = <1>;
csi_out_1: endpoint@3 {
status = "okay";
remote-endpoint = <&vi_in_1>;
q0_link0: irs238xc@3d {
status = "okay";
compatible = "irs238xc";
#size-cells = <0>;
reg = <0x3d>;
physical-addr = <0x3d>; /* 7-bit address, which is what the UB953 wants */
devnode = "video0";
mclk = "extperiph1"; /* Note: extperiph1 <= 24MHz */
frame-sync-mode = <1>;
physical_w = "224";
physical_h = "172";
deserializer = <&ub954q0>;
set_mode_delay_ms = "100000"; /* wait up to 100s for first frame */
/* 5 Mpixel, 30fps linear mode */
mode0 {
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "224";
active_h = "172";
pixel_t = "raw_y12";
csi_pixel_bit_depth = "12";
readout_orientation = "0";
line_length = "224";
inherent_gain = "1";
mclk_multiplier = "170.0";
pix_clk_hz = "400000000";
gain_factor = "10";
min_gain_val = "10";/* 1DB*/
max_gain_val = "160";/* 16DB*/
step_gain_val = "1";
default_gain = "10";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1816577";/*1.816577 */
max_framerate = "30000000";/*30*/
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "34";/* us */
max_exp_time = "550385";/* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
sensor_out_0: endpoint {
vc-id = <0>;
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&csi_in_0>;
q0_link1: ov5695d3@49 {
status = "okay";
compatible = "d3,ov5695d3";
#size-cells = <0>;
reg = <0x49>;
physical-addr = <0x36>; /* 7-bit address */
devnode = "video1";
mclk = "extperiph1"; /* extperiph1 <= 24MHz */
physical_w = "3.684"; /* mm */
physical_h = "2.763"; /* mm */
sensor_model = "ov5695d3";
use_decibel_gain = "false";
use_sensor_mode_id = "true";
mode0 {
mclk_khz = "24000";
num_lanes = <2>;
phy_mode = "DPHY";
csi_pixel_bit_depth = "10";
mode_type = "bayer";
pixel_phase = "bggr";
serdes_pix_clk_hz = "4000000000";
pix_clk_hz = "176160768";
vc_id = "0";
min_gain_val = "0.0625";
max_gain_val = "255.9375";
active_w = "2592";
active_h = "1944";
line_length = "2623";
min_framerate = "30";
max_framerate = "30";
min_exp_time = "68";
max_exp_time = "32996";
ports {
#size-cells = <0>;
status = "okay";
port@0 {
reg = <0>;
sensor_out_1: endpoint {
vc-id = <1>;
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&csi_in_1>;
Another observation is that if I first start capturing VC1 stream using “v4l2-ctl -d /dev/video1 --stream-mmap --stream-count=10000” command, then capturing VC0 stream can be started by “v4l2-ctl -d /dev/video0 --stream-mmap --stream-count=10000” and I can get correct data of the two streams.
But after /dev/video1 capturing ist stopped, the capturing from /dev/video0 hangs again
(with “PXL_SOF syncpt timeout” errors). Any idea how to fix this? Thanks!
