FYI,
you’ll see Invalid sensor placement is set. failure if you’re having camera use-case with more than 6 cameras,
it’s pre-built binary update to treat this failure as harmless,
such as…
- JetPack-4.5.1: Topic 196358.
- JetPack-4.6: Topic 184902.
note,
those changes are not yet integrate to the release-32 code-line, they’re actually workarounds and we’re investigate proper solutions.
