Issues while executing image pyramid sample using pva
Software Version
DRIVE OS 6.0.10.0
[1] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1] Linux
QNX
other
Hardware Platform
[1] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
[1] other
Host Machine Version
other
Issue Description
Hi team, I tried executing the image pyramid pva sample but I got some errors. Kindly help me with this.
Error String
nvidia@tegra-ubuntu:~/akshay/driveworks-5.14/image_pyramid_pva$ ./sample_image_pyramid_pva --input-type=video --video=left_1.h264
Warning: SamplesDataPath::getBasePathFor(): ‘DATA_ROOT’ not found in search paths [/home/nvidia/akshay/driveworks-5.14/image_pyramid_pva/data | /home/nvidia/akshay/driveworks-5.14/image_pyramid_pva.runfiles/av/data | /home/nvidia/akshay/driveworks-5.14/image_pyramid_pva/sample_image_pyramid_pva.runfiles/av/data | /home/nvidia/akshay/driveworks-5.14/image_pyramid_pva/data | /home/nvidia/akshay/driveworks-5.14/data | /home/nvidia/akshay/data | /home/nvidia/data | /home/data]
ProgramArguments: Missing argument ‘dwTracePath’ requested
[21-02-2025 05:34:13] Platform: Detected Drive Orin P3710
[21-02-2025 05:34:13] Adding variable DW_Base:DW_Version
[21-02-2025 05:34:13] Added variable DW_Base:DW_Version
[21-02-2025 05:34:13] Platform: number of GPU devices detected 1
[21-02-2025 05:34:13] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_06_10_03, Arch: ga10b
[21-02-2025 05:34:13] Platform: currently selected GPU device integrated ID 0
[21-02-2025 05:34:13] CUDLAEngine:getDLACount: CUDLA version is = 1004000
[21-02-2025 05:34:13] CUDLAEngine:getDLACount: Number of DLA devices = 2
[21-02-2025 05:34:13] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘./resources’: VirtualFileSystem: Failed to mount ‘./resources/resources.pak’
[21-02-2025 05:34:13] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/home/nvidia/akshay/driveworks-5.14/image_pyramid_pva/data’: VirtualFileSystem: Failed to mount ‘/home/nvidia/akshay/driveworks-5.14/image_pyramid_pva/data/resources.pak’
[21-02-2025 05:34:13] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks/data
[21-02-2025 05:34:13] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks/data/resources.pak’
[21-02-2025 05:34:13] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.14/data
[21-02-2025 05:34:13] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.14/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.14/data/resources.pak’
[21-02-2025 05:34:13] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks/targets/aarch64-Linux/lib/libdw_base.so.5.14
[21-02-2025 05:34:13] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.14/targets/aarch64-Linux/lib/libdw_base.so.5.14
[21-02-2025 05:34:13] SDK: No resources(.pak) mounted, some modules will not function properly
[21-02-2025 05:34:13] SDK: use EGL display as provided
[21-02-2025 05:34:13] [21-02-2025 05:34:13] Initialize DriveWorks SDK v5.14.74
[21-02-2025 05:34:13] [21-02-2025 05:34:13] Release build with GNU 9.3.0 from buildbrain-branch-0-g30b7ba5bb0c against Drive PDK v6.0.8.0
[21-02-2025 05:34:13] SensorFactory::createSensor() → time.nvpps, nvpps-device=/dev/nvpps0
[21-02-2025 05:34:13] Found driver: time.nvpps
[21-02-2025 05:34:13] Can not create time sensor: DW_HAL_CANNOT_OPEN_CHANNEL: EndpointNVPPS: cannot open NVPPS device with name: /dev/nvpps0
Error: Permission denied
[21-02-2025 05:34:13] Initialize DriveWorks VisualizationSDK v5.14.74
[21-02-2025 05:34:13] Initialize DriveWorksGL SDK v5.14.74
[21-02-2025 05:34:13] SensorFactory::createSensor() → camera.virtual, video=left_1.h264
[21-02-2025 05:34:13] Found driver: camera.virtual
[21-02-2025 05:34:13] CameraVirtual: defaulting to non SIPL
[21-02-2025 05:34:13] CameraVirtual: h264 and h265 video format decoding is deprecated. Please switch to a different format.
[21-02-2025 05:34:13] CameraBase: pool size set to 8
[21-02-2025 05:34:13] SyncDriver: GPU device available, enabling CUDA sync
[21-02-2025 05:34:13] SyncDriver: enableCUDAPresync, object successfully created
[21-02-2025 05:34:13] DecoderNvMedia, allocating pool
[21-02-2025 05:34:13] CameraVirtualNvMedia: no seek table found at left_1.h264.seek, seeking is not available.
[21-02-2025 05:34:13] ImageStreamer(NvMedia → CUDA)
SimpleCamera: Camera image: 1920x1208
Camera image with 1920x1208 at 30 FPS
terminate called after throwing an instance of ‘std::runtime_error’
what(): Failed to create PVA stream
Aborted
Dear @akshay.tupkar ,
I don’t see any issue on DRIVE OS 6.0.10 + DW 5.20 with below command.
./sample_image_pyramid_pva --input-type=video --video=/usr/local/driveworks/data/samples/stereo/left_1.h264
Okay @SivaRamaKrishnaNV, but I am using DRIVE OS 6.0.8.1 with DW 5.14
Consider upgrading to latest release to get latest features and fixes.
