Issues with AI workflow in early access of clara
When I execute any workflow involving AI and open http://172.30.1.39:5002/ai to see the status.
It is displaying below and cannot see any output in /nv-clara/ai/output/ folder
{“ai1”: {“OUTPUT_FILE_BASE_PATH”: “/ai/out/wf5_ai”, “ATTIS_URI”: “trtis:8000”, “INPUT_FILE_BASE_PATH”: “/ai/in/wf5_ai”, “roi”: [[88, 440], [53, 465], [61, 14]], “workflow”: “5”, “MESSAGING_MODE”: “DirectInput”, “elapsed_time”: 0.6555595397949219, “CIM_APP_FOLDER_NAME”: “custom_application_vnet”, “status”: “failed(cannot convert float NaN to integer)”, “name”: “wf5_ai”, “id”: “ai1”, “CIM_APP_SKIP_INSTALL”: “true”, “returncode”: 1}, “ai3”: {“OUTPUT_FILE_BASE_PATH”: “/ai/out/wf5-testt”, “ATTIS_URI”: “trtis:8000”, “INPUT_FILE_BASE_PATH”: “/ai/in/wf5-testt”, “roi”: [[88, 440], [53, 465], [61, 14]], “workflow”: “5”, “MESSAGING_MODE”: “DirectInput”, “elapsed_time”: 0.5881328582763672, “CIM_APP_FOLDER_NAME”: “custom_application_vnet”, “status”: “failed(cannot convert float NaN to integer)”, “name”: “wf5-testt”, “id”: “ai3”, “CIM_APP_SKIP_INSTALL”: “true”, “returncode”: 1}, “ai4”: {“OUTPUT_FILE_BASE_PATH”: “/ai/out/wf7-testt”, “ATTIS_URI”: “trtis:8000”, “INPUT_FILE_BASE_PATH”: “/ai/in/wf7-testt”, “roi”: [[88, 440], [53, 465], [61, 14]], “workflow”: “7”, “MESSAGING_MODE”: “DirectInput”, “elapsed_time”: 0.5824475288391113, “CIM_APP_FOLDER_NAME”: “custom_application_vnet”, “status”: “failed(cannot convert float NaN to integer)”, “name”: “wf7-testt”, “id”: “ai4”, “CIM_APP_SKIP_INSTALL”: “true”, “returncode”: 1}, “ai2”: {“OUTPUT_FILE_BASE_PATH”: “/rs/in/wf1-testt”, “ATTIS_URI”: “trtis:8000”, “INPUT_FILE_BASE_PATH”: “/ai/in/wf1-testt”, “roi”: [[88, 440], [53, 465], [61, 14]], “workflow”: “1”, “MESSAGING_MODE”: “DirectInput”, “elapsed_time”: 0.6327085494995117, “CIM_APP_FOLDER_NAME”: “custom_application_vnet”, “status”: “failed(cannot convert float NaN to integer)”, “name”: “wf1-testt”, “id”: “ai2”, “CIM_APP_SKIP_INSTALL”: “true”, “returncode”: 1}}
Can someone help me to get rid of this error.
Do you have reproducible code for this? I am not able to understand the problem from your message.
