Issues with declaring texture in a header file
I have encountered the following problem: I have a .cu file which calls a kernel that utilizes a texture. For compilation reasons I have declared the texture and the kernel call in a header file which is included in the original .cu file. The implementation of the kernel is implemented in a separate .cu file. The problem occurs when I try to launch the kernel, cause then I get a launch failure for the kernel. After I while I realized that the failure occured when I tried access the texture. So, I just tried to include the .cu file with the implementation instead of the header and now all of a sudden it worked without a problem.
Comments?
Textures, constant memory declarations, kernels and other device objects are compiled and assembled at file scope. There is no CUDA linker, so you can’t link across different object files. As a result, you must declare the texture at the same scope as all kernels that use it.
If you don’t want to use your texture as a global variable in header files, there is a little trick I use, don’t know if it’s what you are looking for.
I declare the texture as global variable in my .cu, write a function getref to get the ref on that texture, declare the function in my header file and include this header and I can use it anywhere in my program :
*** .cu ***
texture<unsigned short, 2, cudaReadModeElementType> ref;
texture<unsigned short, 2, cudaReadModeElementType> &get_ref(void)
	return ref;
*** .h ***
texture<unsigned short, 2, cudaReadModeElementType> &get_ref(void);
*** .c ***
cudaBindTextureToArray(get_ref(), ref_ary);
*** .cu ***
	return ref;
*** .h ***
*** .c ***
