The 510.06 driver is downloaded from here (GeForce driver).
The issue is, when I run a popular GPU render benchmark “OctaneBench® 2020.1” downloaded from here, its Linux version works fine in WSL2, but the Windows version freezes after I clicked “run” and finally gives me an error:
The GPU is shown in the error message. The system is Windows 10 version 21H2 on Core i9-9900K. The same problem can also be found on other CPU and GPU combinations (including 510.06 Quadro driver). Other info:
Cuda version: 11.6
WSL2 version: 5.10.60.1
WSL2 distro: Ubuntu 20.04
Do you have any idea to solve or work around this issue?
