We are trying to perform OTA update from 35.2.1 to 35.4.1 on Jetson Orin NX16GB modules with L4T 35.2.1on an NVMe drive with an Orin NX devkit.
When generating an OTA payload to update to 35.4.1, we are capturing the rootfs from another Orin NX with 35.4.1 in a devkit with the following method: Flashing Support — Jetson Linux Developer Guide documentation
I generate the OTA payload for 35.4.1 using the following command:
sudo -E ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh -s -f system.img --external-device nvme0n1 jetson-orin-nano-devkit R35-2
The image-based OTA is uploaded to the Orin and I initiate the update according to the instructions here: Software Packages and the Update Mechanism — Jetson Linux Developer Guide documentation
After the ota payload is ran, i run a sudo reboot command and I see the following error in the UART logs and the system doesn’t complete boot.
What does this error mean and how can I fix it?
[ 10.701588] nvme nvme0: Shutdown timeout set to 8 seconds
[ 10.722802] nvme nvme0: 8/0/0 default/read/poll queues
[ 10.736075] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 10.746905] Freeing unused kernel memory: 3968K
[ 10.758722] Run /init as init process
[ 10.774965] Root device found: PARTUUID=123924e5-cd65-4f0e-bb98-d8fa0723d2f9
[ 23.157381] ERROR: PARTUUID=123924e5-cd65-4f0e-bb98-d8fa0723d2f9 mount fail...
I have attached full UART logs below of the update process as well as the failure to boot after the update completes.
out_intitrd_clone_x1.txt (827.9 KB)
