Apply this patch without the kernel GPIO patch and add the 40pin head SPI pin configure.
diff --git a/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-a02.dtsi b/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-a02.dtsi
index b520de5..56f9140 100644
--- a/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-a02.dtsi
+++ b/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-a02.dtsi
@@ -1,6 +1,6 @@
-/*This dtsi file was generated by T210_P3448_SKU2_pinmux.xlsm Revision: 8 */
+/*This dtsi file was generated by jetson_nano_module.xlsm Revision: 1.05 */
- * Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
+ * Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
@@ -26,35 +26,13 @@
gpio_default: default {
gpio-input = <
- TEGRA_GPIO(BB, 0)
- TEGRA_GPIO(B, 4)
- TEGRA_GPIO(B, 5)
- TEGRA_GPIO(B, 6)
- TEGRA_GPIO(B, 7)
- TEGRA_GPIO(DD, 0)
- TEGRA_GPIO(E, 6)
- TEGRA_GPIO(S, 5)
TEGRA_GPIO(A, 5)
TEGRA_GPIO(X, 4)
TEGRA_GPIO(X, 5)
TEGRA_GPIO(X, 6)
TEGRA_GPIO(Y, 1)
- TEGRA_GPIO(Y, 2)
- TEGRA_GPIO(V, 0)
TEGRA_GPIO(V, 1)
- TEGRA_GPIO(Z, 0)
TEGRA_GPIO(Z, 2)
- TEGRA_GPIO(J, 5)
- TEGRA_GPIO(J, 6)
- TEGRA_GPIO(J, 4)
- TEGRA_GPIO(J, 7)
- TEGRA_GPIO(G, 2)
- TEGRA_GPIO(G, 3)
- TEGRA_GPIO(C, 0)
- TEGRA_GPIO(C, 1)
- TEGRA_GPIO(C, 2)
- TEGRA_GPIO(C, 3)
- TEGRA_GPIO(C, 4)
TEGRA_GPIO(H, 2)
TEGRA_GPIO(H, 5)
TEGRA_GPIO(H, 6)
@@ -64,7 +42,6 @@
gpio-output-low = <
TEGRA_GPIO(S, 7)
TEGRA_GPIO(T, 0)
- TEGRA_GPIO(A, 6)
TEGRA_GPIO(Z, 3)
TEGRA_GPIO(H, 0)
TEGRA_GPIO(H, 3)
@@ -74,7 +51,9 @@
TEGRA_GPIO(I, 2)
gpio-output-high = <
+ TEGRA_GPIO(A, 6)
TEGRA_GPIO(X, 3)
+ TEGRA_GPIO(CC, 7)
diff --git a/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi b/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
index ac8bda8..56f9140 100644
--- a/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
+++ b/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
@@ -1,6 +1,6 @@
-/*This dtsi file was generated by T210_P3448_SKU2_pinmux.xlsm Revision: 17 */
@@ -26,43 +26,23 @@
gpio-input = <
- TEGRA_GPIO(BB, 0)
- TEGRA_GPIO(B, 4)
- TEGRA_GPIO(B, 5)
- TEGRA_GPIO(B, 6)
- TEGRA_GPIO(B, 7)
- TEGRA_GPIO(DD, 0)
- TEGRA_GPIO(E, 6)
- TEGRA_GPIO(S, 5)
TEGRA_GPIO(A, 5)
TEGRA_GPIO(X, 4)
TEGRA_GPIO(X, 5)
TEGRA_GPIO(X, 6)
TEGRA_GPIO(Y, 1)
- TEGRA_GPIO(Y, 2)
- TEGRA_GPIO(V, 0)
TEGRA_GPIO(V, 1)
- TEGRA_GPIO(Z, 0)
TEGRA_GPIO(Z, 2)
- TEGRA_GPIO(J, 5)
- TEGRA_GPIO(J, 6)
- TEGRA_GPIO(J, 4)
- TEGRA_GPIO(J, 7)
- TEGRA_GPIO(G, 2)
- TEGRA_GPIO(G, 3)
- TEGRA_GPIO(C, 0)
- TEGRA_GPIO(C, 1)
- TEGRA_GPIO(C, 2)
- TEGRA_GPIO(C, 3)
- TEGRA_GPIO(C, 4)
TEGRA_GPIO(H, 2)
TEGRA_GPIO(H, 5)
TEGRA_GPIO(H, 6)
+ TEGRA_GPIO(I, 1)
TEGRA_GPIO(CC, 4)
gpio-output-low = <
TEGRA_GPIO(S, 7)
TEGRA_GPIO(T, 0)
+ TEGRA_GPIO(Z, 3)
TEGRA_GPIO(H, 0)
TEGRA_GPIO(H, 3)
TEGRA_GPIO(H, 4)
@@ -73,7 +53,6 @@
TEGRA_GPIO(A, 6)
TEGRA_GPIO(X, 3)
- TEGRA_GPIO(I, 1)
TEGRA_GPIO(CC, 7)
diff --git a/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-a02.dtsi b/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-a02.dtsi
index 5d889ec..9be96f8 100644
--- a/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-a02.dtsi
+++ b/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-a02.dtsi
@@ -1,6 +1,6 @@
@@ -135,7 +135,7 @@
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
- nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
+ nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
pex_l0_rst_n_pa0 {
@@ -144,7 +144,7 @@
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
pex_l1_clkreq_n_pa4 {
@@ -153,7 +153,7 @@
pex_l1_rst_n_pa3 {
@@ -162,7 +162,7 @@
pex_wake_n_pa2 {
@@ -171,7 +171,55 @@
+ sdmmc1_clk_pm0 {
+ nvidia,pins = "sdmmc1_clk_pm0";
+ nvidia,function = "sdmmc1";
+ nvidia,pull = <TEGRA_PIN_PULL_NONE>;
+ nvidia,tristate = <TEGRA_PIN_DISABLE>;
+ nvidia,enable-input = <TEGRA_PIN_ENABLE>;
+ sdmmc1_cmd_pm1 {
+ nvidia,pins = "sdmmc1_cmd_pm1";
+ nvidia,pull = <TEGRA_PIN_PULL_UP>;
+ sdmmc1_dat0_pm5 {
+ nvidia,pins = "sdmmc1_dat0_pm5";
+ sdmmc1_dat1_pm4 {
+ nvidia,pins = "sdmmc1_dat1_pm4";
+ sdmmc1_dat2_pm3 {
+ nvidia,pins = "sdmmc1_dat2_pm3";
+ sdmmc1_dat3_pm2 {
+ nvidia,pins = "sdmmc1_dat3_pm2";
sdmmc3_clk_pp0 {
@@ -264,6 +312,14 @@
+ clk_32k_out_py5 {
+ nvidia,pins = "clk_32k_out_py5";
+ nvidia,function = "soc";
pz1 {
nvidia,pins = "pz1";
@@ -495,70 +551,6 @@
/* GPIO Pin Configuration */
- aud_mclk_pbb0 {
- nvidia,pins = "aud_mclk_pbb0";
- nvidia,function = "rsvd1";
- nvidia,pull = <TEGRA_PIN_PULL_UP>;
- nvidia,tristate = <TEGRA_PIN_DISABLE>;
- nvidia,enable-input = <TEGRA_PIN_ENABLE>;
- spi2_mosi_pb4 {
- nvidia,pins = "spi2_mosi_pb4";
- nvidia,function = "rsvd2";
- nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
- spi2_miso_pb5 {
- nvidia,pins = "spi2_miso_pb5";
- spi2_sck_pb6 {
- nvidia,pins = "spi2_sck_pb6";
- spi2_cs0_pb7 {
- nvidia,pins = "spi2_cs0_pb7";
- spi2_cs1_pdd0 {
- nvidia,pins = "spi2_cs1_pdd0";
- pe6 {
- nvidia,pins = "pe6";
- nvidia,function = "rsvd0";
- cam_af_en_ps5 {
- nvidia,pins = "cam_af_en_ps5";
cam1_pwdn_ps7 {
nvidia,pins = "cam1_pwdn_ps7";
@@ -631,22 +623,6 @@
- lcd_te_py2 {
- nvidia,pins = "lcd_te_py2";
- lcd_bl_pwm_pv0 {
- nvidia,pins = "lcd_bl_pwm_pv0";
- nvidia,function = "rsvd3";
lcd_bl_en_pv1 {
nvidia,pins = "lcd_bl_en_pv1";
@@ -655,14 +631,6 @@
- pz0 {
- nvidia,pins = "pz0";
pz2 {
nvidia,pins = "pz2";
@@ -679,94 +647,6 @@
- dap4_din_pj5 {
- nvidia,pins = "dap4_din_pj5";
- dap4_dout_pj6 {
- nvidia,pins = "dap4_dout_pj6";
- dap4_fs_pj4 {
- nvidia,pins = "dap4_fs_pj4";
- dap4_sclk_pj7 {
- nvidia,pins = "dap4_sclk_pj7";
- uart2_rts_pg2 {
- nvidia,pins = "uart2_rts_pg2";
- uart2_cts_pg3 {
- nvidia,pins = "uart2_cts_pg3";
- spi1_mosi_pc0 {
- nvidia,pins = "spi1_mosi_pc0";
- spi1_miso_pc1 {
- nvidia,pins = "spi1_miso_pc1";
- spi1_sck_pc2 {
- nvidia,pins = "spi1_sck_pc2";
- spi1_cs0_pc3 {
- nvidia,pins = "spi1_cs0_pc3";
- spi1_cs1_pc4 {
- nvidia,pins = "spi1_cs1_pc4";
wifi_en_ph0 {
nvidia,pins = "wifi_en_ph0";
@@ -834,8 +714,8 @@
nfc_int_pi1 {
nvidia,pins = "nfc_int_pi1";
+ nvidia,tristate = <TEGRA_PIN_ENABLE>;
@@ -847,6 +727,15 @@
+ pcc7 {
+ nvidia,pins = "pcc7";
+ nvidia,function = "rsvd0";
+ nvidia,enable-input = <TEGRA_PIN_DISABLE>;
usb_vbus_en0_pcc4 {
nvidia,pins = "usb_vbus_en0_pcc4";
@@ -858,6 +747,14 @@
pinmux_unused_lowpower: unused_lowpower {
+ aud_mclk_pbb0 {
+ nvidia,pins = "aud_mclk_pbb0";
+ nvidia,function = "rsvd1";
+ nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
dvfs_clk_pbb2 {
nvidia,pins = "dvfs_clk_pbb2";
@@ -914,89 +811,97 @@
- dmic3_clk_pe4 {
- nvidia,pins = "dmic3_clk_pe4";
+ spi2_mosi_pb4 {
+ nvidia,pins = "spi2_mosi_pb4";
- dmic3_dat_pe5 {
- nvidia,pins = "dmic3_dat_pe5";
+ spi2_miso_pb5 {
+ nvidia,pins = "spi2_miso_pb5";
- cam_rst_ps4 {
- nvidia,pins = "cam_rst_ps4";
+ spi2_sck_pb6 {
+ nvidia,pins = "spi2_sck_pb6";
+ nvidia,function = "rsvd2";
- cam_flash_en_ps6 {
- nvidia,pins = "cam_flash_en_ps6";
+ spi2_cs0_pb7 {
+ nvidia,pins = "spi2_cs0_pb7";
- cam1_strobe_pt1 {
- nvidia,pins = "cam1_strobe_pt1";
+ spi2_cs1_pdd0 {
+ nvidia,pins = "spi2_cs1_pdd0";
- sdmmc1_clk_pm0 {
- nvidia,pins = "sdmmc1_clk_pm0";
+ dmic3_clk_pe4 {
+ nvidia,pins = "dmic3_clk_pe4";
- sdmmc1_cmd_pm1 {
- nvidia,pins = "sdmmc1_cmd_pm1";
+ dmic3_dat_pe5 {
+ nvidia,pins = "dmic3_dat_pe5";
- sdmmc1_dat0_pm5 {
- nvidia,pins = "sdmmc1_dat0_pm5";
+ pe6 {
+ nvidia,pins = "pe6";
+ cam_rst_ps4 {
+ nvidia,pins = "cam_rst_ps4";
- sdmmc1_dat1_pm4 {
- nvidia,pins = "sdmmc1_dat1_pm4";
+ cam_af_en_ps5 {
+ nvidia,pins = "cam_af_en_ps5";
- sdmmc1_dat2_pm3 {
- nvidia,pins = "sdmmc1_dat2_pm3";
+ cam_flash_en_ps6 {
+ nvidia,pins = "cam_flash_en_ps6";
- sdmmc1_dat3_pm2 {
- nvidia,pins = "sdmmc1_dat3_pm2";
+ cam1_strobe_pt1 {
+ nvidia,pins = "cam1_strobe_pt1";
@@ -1058,6 +963,22 @@
+ lcd_te_py2 {
+ nvidia,pins = "lcd_te_py2";
+ lcd_bl_pwm_pv0 {
+ nvidia,pins = "lcd_bl_pwm_pv0";
+ nvidia,function = "rsvd3";
lcd_rst_pv2 {
nvidia,pins = "lcd_rst_pv2";
@@ -1082,9 +1003,9 @@
- clk_32k_out_py5 {
- nvidia,pins = "clk_32k_out_py5";
+ pz0 {
+ nvidia,pins = "pz0";
@@ -1114,6 +1035,54 @@
+ dap4_din_pj5 {
+ nvidia,pins = "dap4_din_pj5";
+ dap4_dout_pj6 {
+ nvidia,pins = "dap4_dout_pj6";
+ dap4_fs_pj4 {
+ nvidia,pins = "dap4_fs_pj4";
+ dap4_sclk_pj7 {
+ nvidia,pins = "dap4_sclk_pj7";
+ uart2_rts_pg2 {
+ nvidia,pins = "uart2_rts_pg2";
+ uart2_cts_pg3 {
+ nvidia,pins = "uart2_cts_pg3";
uart1_rts_pu2 {
nvidia,pins = "uart1_rts_pu2";
@@ -1210,6 +1179,46 @@
+ spi1_mosi_pc0 {
+ nvidia,pins = "spi1_mosi_pc0";
+ spi1_miso_pc1 {
+ nvidia,pins = "spi1_miso_pc1";
+ spi1_sck_pc2 {
+ nvidia,pins = "spi1_sck_pc2";
+ spi1_cs0_pc3 {
+ nvidia,pins = "spi1_cs0_pc3";
+ spi1_cs1_pc4 {
+ nvidia,pins = "spi1_cs1_pc4";
spi4_mosi_pc7 {
nvidia,pins = "spi4_mosi_pc7";
@@ -1306,15 +1315,6 @@
- pcc7 {
- nvidia,pins = "pcc7";
- nvidia,tristate = <TEGRA_PIN_ENABLE>;
- nvidia,enable-input = <TEGRA_PIN_DISABLE>;
spdif_out_pcc2 {
nvidia,pins = "spdif_out_pcc2";
diff --git a/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi b/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
index 60e5bb4..9be96f8 100644
--- a/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
+++ b/kernel-dts/porg-platforms/tegra210-porg-pinmux-p3448-0002-b00.dtsi
@@ -1,6 +1,6 @@
@@ -174,6 +174,54 @@
+ sdmmc1_clk_pm0 {
+ sdmmc1_cmd_pm1 {
+ sdmmc1_dat0_pm5 {
+ sdmmc1_dat1_pm4 {
+ sdmmc1_dat2_pm3 {
+ sdmmc1_dat3_pm2 {
sdmmc3_clk_pp0 {
nvidia,pins = "sdmmc3_clk_pp0";
nvidia,function = "sdmmc3";
@@ -272,6 +320,14 @@
+ pz1 {
+ nvidia,pins = "pz1";
pz5 {
nvidia,pins = "pz5";
- aud_mclk_pbb0 {
- spi2_mosi_pb4 {
- spi2_miso_pb5 {
- spi2_sck_pb6 {
- spi2_cs0_pb7 {
- spi2_cs1_pdd0 {
- pe6 {
- cam_af_en_ps5 {
cam1_pwdn_ps7 {
- lcd_te_py2 {
- lcd_bl_pwm_pv0 {
lcd_bl_en_pv1 {
- pz0 {
pz2 {
@@ -671,92 +639,12 @@
- dap4_din_pj5 {
- dap4_dout_pj6 {
- dap4_fs_pj4 {
- dap4_sclk_pj7 {
- uart2_rts_pg2 {
- uart2_cts_pg3 {
- spi1_mosi_pc0 {
- spi1_miso_pc1 {
- spi1_sck_pc2 {
- spi1_cs0_pc3 {
- spi1_cs1_pc4 {
+ pz3 {
+ nvidia,pins = "pz3";
wifi_en_ph0 {
@@ -827,8 +715,8 @@
gps_en_pi2 {
@@ -859,6 +747,14 @@
+ aud_mclk_pbb0 {
dvfs_clk_pbb2 {
@@ -915,89 +811,97 @@
- dmic3_clk_pe4 {
+ spi2_mosi_pb4 {
- dmic3_dat_pe5 {
+ spi2_miso_pb5 {
- cam_rst_ps4 {
+ spi2_sck_pb6 {
+ spi2_cs0_pb7 {
- cam1_strobe_pt1 {
+ spi2_cs1_pdd0 {
- sdmmc1_clk_pm0 {
+ dmic3_clk_pe4 {
- sdmmc1_cmd_pm1 {
+ dmic3_dat_pe5 {
- sdmmc1_dat0_pm5 {
+ pe6 {
+ cam_rst_ps4 {
- sdmmc1_dat1_pm4 {
+ cam_af_en_ps5 {
- sdmmc1_dat2_pm3 {
- sdmmc1_dat3_pm2 {
+ cam1_strobe_pt1 {
@@ -1059,6 +963,22 @@
+ lcd_te_py2 {
+ lcd_bl_pwm_pv0 {
lcd_rst_pv2 {
@@ -1083,16 +1003,8 @@
- pz1 {
- nvidia,pins = "pz1";
- pz3 {
- nvidia,pins = "pz3";
+ pz0 {
@@ -1123,6 +1035,54 @@
+ dap4_din_pj5 {
+ dap4_dout_pj6 {
+ dap4_fs_pj4 {
+ dap4_sclk_pj7 {
+ uart2_rts_pg2 {
+ uart2_cts_pg3 {
uart1_rts_pu2 {
@@ -1219,6 +1179,46 @@
+ spi1_mosi_pc0 {
+ spi1_miso_pc1 {
+ spi1_sck_pc2 {
+ spi1_cs0_pc3 {
+ spi1_cs1_pc4 {
spi4_mosi_pc7 {
