I recently purchased a dev kit; and have tried to install a WIFI / BT card after a few days of use.
When I went to remove the M.2 screw; the head had started to strip (as if it has been fused or glued the standoff), with multiple PH #2 drivers.
I have also attempted to replace the standoff; but that seems glued to the board, and is unable to be removed.
I don’t want to have to cut / drill the screw out as that runs the risk of metal shavings entering the M.2 and SOM connectors.
Nope, not on the screw head or standoff; it is as if the heat from the CPU has started to melt the screw head; and, or glue (it looks like the CPU is directly above the M.2 screw)
The card doesn’t connect properly without being screwed in; plus the plugs on the antenna cables touch some of the the solder on the SOM as the card it too high without the screw holding it down
