My NVstreamer is not loading more and when i tryed to reinstall i receive this message:
Can you share the information of your setup?
I used the SDK Manager installer using a seond linux ubuntu machine and run all commands that have on the docs, everything works fine, but after sometime and installing other tools, like jetson-stats, flask and jetson-examples the service of nvstreamer do not up more.
i ran this command one time:
sudo docker compose -f compose_nvstreamer.yaml down --remove-orphans
packs.txt (448.8 KB)
Whats more details do you need, i can extract more info.
I downloaded again using my login (Jetson Platform Services Reference Workflow & Resources | NVIDIA NGC) and choose another type on option (no teams) and works fine!
