Hi everyone,
I am currently working with Segment Anything using the Mobile SAM model of Issac ROS.
I have few queries like
- There is file name isaac_ros_assets/isaac_ros_segment_anything/quickstart_interface_specs.json in this all the keys like image , camera_info and prompt are inputs to the segmentation? What is prompt input actually please tell me more on the prompt input which the /detectnet/detections is passing is it directly data from the zed camera or any node is getting some other data then with that the /detectnet/detections topic is created?
“input_image”: {
“width”: 1200,
“height”: 632
“subscribed_topics”: {
“image”: “/image”,
“camera_info”: “/camera_info”,
“prompt”: “/detectnet/detections”
- If /detectnet/detections gives the detections like person or other objects directly the segment everything will not work right ? only on the detections that is the class id which the topic data is giving will be segmented right?
- I want to know the exact creation of the /detectnet/detections topic data
ros2 bag info segment_anything_sample_data/
Files: segment_anything_sample_data_0.db3
Bag size: 65.3 MiB
Storage id: sqlite3
Duration: 2.891s
Start: Feb 16 2024 17:54:25.952 (1708086265.952)
End: Feb 16 2024 17:54:28.843 (1708086268.843)
Topic information: Topic: /camera_info | Type: sensor_msgs/msg/CameraInfo | Count: 29 | Serialization Format: cdr
Topic: /detectnet/detections | Type: vision_msgs/msg/Detection2DArray | Count: 29 | Serialization Format: cdr
Topic: /image | Type: sensor_msgs/msg/Image | Count: 30 | Serialization Format: cdr
Please help
