Issues with simpleCUBLAS
I’ve been working on running the simpleCUBLAS demo that comes with the CUDA SDK. The demo runs correctly under emulation, but the program fails to run when compiled to run on a GPU. Visual C++ reports an error 0xC0000005 when loading the libraries for the executable. This happens whether the code is built with the Debug or Release configuration. A similar issue is happening with another project that uses CUBLAS. Non-CUBLAS projects are running correctly, although only a few have been run (ie. bandwidthTest, radixSort).
Does anyone know what could be the cause?
Here is the Visual C++ output:
[codebox]‘simpleCUBLAS.exe’: Loaded ‘C:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\bin\win32\Debug\simpleCUBLAS.exe’, Symbols loaded.
‘simpleCUBLAS.exe’: Loaded ‘C:\WINDOWS\system32\ntdll.dll’
‘simpleCUBLAS.exe’: Loaded ‘C:\WINDOWS\system32\kernel32.dll’
‘simpleCUBLAS.exe’: Loaded ‘C:\CUDA\bin\cublas.dll’, Binary was not built with debug information.
Debugger:: An unhandled non-continuable exception was thrown during process load
The program ‘[1032] simpleCUBLAS.exe: Native’ has exited with code -1073741819 (0xc0000005).[/codebox]
Here is some information about the system and software involved:
Software:
Windows XP Service Pack 3, 32 bits
CUDA Driver version 190.38
CUDA Toolkit 2.3
CUDA SDK 2.3
Visual C++ 2008 Express Edition SP1 with Microsoft C/C++ Compiler 15.0.30729.1
System:
Intel Core 2 CPU 6300 @ 1.86 Ghz
2.75 GB of RAM
Two graphics cards: GeForce 8500 GT, GeForce 8800 GTX
