My environment:
Ubuntu 14.04 with kernel linux-image-4.2.0-27-generic
OFED 3.2-2.0.0.0
During installation of linux kernel > 4.2.0-27 DKMS reports errors.
Setting up linux-image-4.2.0-30-generic (4.2.0-30.36~14.04.1) …
Running depmod.
update-initramfs: deferring update (hook will be called later)
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.2.0-30-generic /boot/vmlinuz-4.2.0-30-generic
run-parts: executing /etc/kernel/postinst.d/dkms 4.2.0-30-generic /boot/vmlinuz-4.2.0-30-generic
File “/usr/share/apport/package-hooks/dkms_packages.py”, line 98, in
with apport.fileutils.make_report_file(report) as f:
AttributeError: ‘module’ object has no attribute ‘make_report_file’
Error! Bad return status for module build on kernel: 4.2.0-30-generic (x86_64)
Consult /var/lib/dkms/srp/1.5.5/build/make.log for more information.
Consult /var/lib/dkms/iser/1.7.0/build/make.log for more information.
: Unable to find an initial ram disk that I know how to handle.
Will not try to make an initrd.
When there is no OFED package in the system all goes fine.
cat /var/lib/dkms/srp/1.5.5/build/make.log
DKMS make.log for srp-1.5.5 for kernel 4.2.0-30-generic (x86_64)
Fri Mar 18 13:03:56 UTC 2016
makefile:17: /usr/src/ofa_kernel/default/configure.mk.kernel: No such file or directory
grep: srp.spec: No such file or directory
make: *** No rule to make target `/usr/src/ofa_kernel/default/configure.mk.kernel’. Stop.
cat /var/lib/dkms/iser/1.7.0/build/make.log
DKMS make.log for iser-1.7.0 for kernel 4.2.0-30-generic (x86_64)
makefile:48: /usr/src/ofa_kernel/default/configure.mk.kernel: No such file or directory
grep: iser.spec: No such file or directory
Prior to linux image 4.2.0-27 updates was successful too.
