It appears that the nvinfer element is not freeing some memory
• Hardware Platform (Jetson / GPU) : Jetson Orin Nx
• DeepStream Version : 6.3.0
• JetPack Version (valid for Jetson only) : 5.1.2
• TensorRT Version : 8.5.2.2-1+cuda11.4
• Issue Type( questions, new requirements, bugs) : bugs
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) : I’ll attach the sample code.
I’m developing an application that uses deepstream to build a pipeline to infer video.
I noticed that the GPU memory was increasing as I removed and recreated the pipeline, and after a few iterations, the application would crash with a message that the GPU usage had reached 99%.
I narrowed down the scope of the problem and came to our own conclusion that the nvinfer element was not properly destroying memory.
Attached is a sample code that creates just the nvinfer element, sets it to PLAYING, then NULLs it, and repeats. I’ve set it to run every 5 seconds, and it shows a 10MB increase on each iteration.
I’m assuming it’s not being handled correctly by nvinfer, but I’d like to know if there’s a process I’m missing to free the memory.
CMakeLists.txt (879 Bytes)
dsserver_pgie_config.txt (3.5 KB)
The cpp code didn’t upload, so I’m posting it here.
// Created by moony on 24. 1. 31.
//#include <spdlog/spdlog.h>
#include <iostream>
#include <gst/gst.h>
GstElement *nvinfer = nullptr;
int count = 0;
gboolean creatAndDestroy(void* ptr) {
//    spdlog::debug("{}", __func__);
    std::cout << __func__;
    if (count % 2 == 0) {
        nvinfer = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
        g_object_set(G_OBJECT(nvinfer),
                     "config-file-path",
                     "/tmp/jetson-streaming/infer-strm-svr/gpu-leak-only-element/dsserver_pgie_config.txt",
                     nullptr);
        gst_element_set_state(nvinfer, GST_STATE_PLAYING);
    } else {
        gst_element_set_state(nvinfer, GST_STATE_NULL);
        gst_object_unref(nvinfer);
    count++;
    return TRUE;
int main (int argc, char *argv[]) {
//    spdlog::set_level(spdlog::level::debug);
    gst_init(&argc, &argv);
    auto mainLoop = g_main_loop_new(nullptr, FALSE);
    g_timeout_add_seconds(5, (GSourceFunc)creatAndDestroy, nullptr);
    g_main_loop_run(mainLoop);
    return 0;
The location of the config-file-path that you set as a property to infer and the location of the model file, etc. within this file should be customized to your environment.
The situation where GPU memory is increased is through jtop.
Could you tell us why do you need to create and destroy the nvinfer frequently? In theory, you can just create plugin once like below:
create plugin-> loop(GST_STATE_PLAYING->GST_STATE_NULL->GST_STATE_PLAYING) -> unref plugin
I’m using a pipeline configured as follows.
Receive input from an RTSP source and decode the video. Infer the decoded video using nvinfer. Encode the video back to multiple resolutions. Serve the encoded video and inferred data using the RTSP server.
In this scenario, if the RTSP source changes or the resolution to be served changes, the pipeline is torn down and recreated. As far as I can tell, each time nvinfer iterates through the state GST_STATE_PLAYING->GST_STATE_NULL->GST_STATE_PLAYING, memory is being piled up instead of being released, is that correct?
Yes, but it will stabilize at a fixed value. Could you try that without making and unref the nvinfer plugin in a loop?
