It does not select the right gpu
Hi all,
I have a GeForce 285 and 580. The 285 is my primary since I am using that with the monitor and the 580 totally dedicated to Cuda computing.
I wrote my code, i specified “compute_20,sm_20” and also
int deviceCount, device;
	cudaDeviceProp prop;
	 // Num. of Device Count
		cudaGetDeviceCount(&deviceCount);
        printf("\nDevice found:\n");
		for(i=0; i<deviceCount; i++)	{
			cudaGetDeviceProperties(&prop, i);
			printf("%s\n", prop.name);
        // Device Selection
		device = 0;
        cudaSetDevice(device);
// Current Device Detection
        cudaGetDeviceProperties(&prop, device);
        printf("Using device %d: %s \n", device, prop.name);
To select the 580 (that is 0, 285 is 1)
Well, when I run it, if I set a thread/block until 512 everything fine, but from 513 going over I get error…
I guess it is using anyway the 285 since it has the 512 threads/block limit, while on 580 this is 1024.
What could I do?
Update: I toke the 285 out from the pc, but I still get the error.
It is related with the “Generate GPU Debug Information” field.
When this is “Yes”, I can run my program with up to 768 (only limited by Shared Memory).
But if it is “No.” then I get errors, and it runs fine again only with =< 512 kernels.
Any idea?
Where exactly have you specified “compute_20,sm_20”? It seems you put it somewhere where it is only used for debug builds, not for release builds.
In:
Property → CUDA C/C++ → Device → Code Generation
And I double checked, the configuration is the Release one
