1st Try = I tried to create a critical area, which did not work by locking the code “Apparently if there are more than 3 SM being used it creates a deadlock in the critical area”.
Exemplo: 1 2 4 2 5 6 2 1 3 5 6
Frequência
1=2
2=3
3=1
4=1
5=2
6=2
Problem = Logical and easy, a blank <String ID, int value> structure is started if the element does not exist and added, if its support exists and added with the support of the element found. The problem starts when everyone tries to read the first empty position and all threads write their element in the first position of the list, as said I could not use a critical area, I believe I can create something with some special function from the atomic functions like atomicCAS .
The source code I want to create is this:
auto indexAtual = blockIdx.x * blockDim.x + threadIdx.x;
if (indexAtual < x ) {
int index = 0;
bool newFlag = true;
while (newFlag) {
if (0 == compare(new_canditatos_cont_suporte[index]->ItemId, "")) {
(*new_canditatos_cont_suporte_size)++;
my_strcpy(new_canditatos_cont_suporte[index]->ItemId,new_canditatos[indexAtual]->ItemId);
new_canditatos_cont_suporte[index]->indexArrayMap = new_canditatos[indexAtual]->indexArrayMap;
new_canditatos_cont_suporte[index]->suporte = new_canditatos[indexAtual]->suporte;
newFlag = false;
} else if (0 == compare(new_canditatos_cont_suporte[index]->ItemId, new_canditatos[indexAtual]->ItemId)) {
new_canditatos_cont_suporte[index]->suporte += new_canditatos[indexAtual]->suporte;
newFlag = false;
} else {
index++;
