Description
I convert a onnx model to tensorrt.But found there is a “inf” result in a intermedia output from a Pow(2) operator. the dtype of the operator’s input and output tensor are all float32. Is seems precision reduced in operator Pow. How can I forbid the precision reduction?
convert log :
the result log:
the convert command line: trtexec --onnx="$onnx" \ --saveEngine="$engine_file" \ --verbose --explicitBatch --workspace=262144
tensorrt version : TensorRT v8204
Could you please try on the latest TensorRT version 8.4 EA. If still face this issue, please share with us the issue repro model/script and steps to try from our end.
Thank you.
NVES
May 27, 2022, 12:06pm
3
Hi ,
We recommend you to check the supported features from the below link.
These support matrices provide a look into the supported platforms, features, and hardware capabilities of the NVIDIA TensorRT 8.4.3 APIs, parsers, and layers.
You can refer below link for all the supported operators list.
For unsupported operators, you need to create a custom plugin to support the operation
<!--- SPDX-License-Identifier: Apache-2.0 -->
# Supported ONNX Operators
TensorRT 8.4 supports operators up to Opset 17. Latest information of ONNX operators can be found [here](https://github.com/onnx/onnx/blob/master/docs/Operators.md)
TensorRT supports the following ONNX data types: DOUBLE, FLOAT32, FLOAT16, INT8, and BOOL
> Note: There is limited support for INT32, INT64, and DOUBLE types. TensorRT will attempt to cast down INT64 to INT32 and DOUBLE down to FLOAT, clamping values to `+-INT_MAX` or `+-FLT_MAX` if necessary.
See below for the support matrix of ONNX operators in ONNX-TensorRT.
## Operator Support Matrix
| Operator | Supported | Supported Types | Restrictions |
| Abs | Y | FP32, FP16, INT32 |
| Acos | Y | FP32, FP16 |
| Acosh | Y | FP32, FP16 |
| Add | Y | FP32, FP16, INT32 |
This file has been truncated. show original
