It seems that CUDA kernel are not running parallel
Hello. below is my Hello World kernel code for CUDA.
__global__ void _cuHelloWorld()
         printf("threadindex : %d, blockindex : %d\r\n", threadIdx.x, blockIdx.x);
void cuHelloWorld()
        printf("Hello World by GPU origin function\r\n");
        printf("<<<7,7>>> block 7 thread 7\r\n");
        _cuHelloWorld<<<7,7>>>();
        cudaDeviceSynchronize(); //CPU wait for CUDA completion.
And the output on the console was as follows:
[100%] Built target CUDARunOrderVisualization
ubuntu@tegra-ubuntu:~/Desktop/MyZEDSample/MySample/CUDAPractice/CUDARunOrderVisualization/build$ ./CUDARunOrderVisualization
Hello World by CPU
threadindex : 0, blockindex : 0
threadindex : 1, blockindex : 0
threadindex : 2, blockindex : 0
threadindex : 3, blockindex : 0
threadindex : 4, blockindex : 0
threadindex : 5, blockindex : 0
threadindex : 6, blockindex : 0
threadindex : 0, blockindex : 1
threadindex : 1, blockindex : 1
threadindex : 2, blockindex : 1
threadindex : 3, blockindex : 1
threadindex : 4, blockindex : 1
threadindex : 5, blockindex : 1
threadindex : 6, blockindex : 1
threadindex : 0, blockindex : 4
threadindex : 1, blockindex : 4
threadindex : 2, blockindex : 4
threadindex : 3, blockindex : 4
threadindex : 4, blockindex : 4
threadindex : 5, blockindex : 4
threadindex : 6, blockindex : 4
threadindex : 0, blockindex : 2
threadindex : 1, blockindex : 2
threadindex : 2, blockindex : 2
threadindex : 3, blockindex : 2
threadindex : 4, blockindex : 2
threadindex : 5, blockindex : 2
threadindex : 6, blockindex : 2
threadindex : 0, blockindex : 5
threadindex : 1, blockindex : 5
threadindex : 2, blockindex : 5
threadindex : 3, blockindex : 5
threadindex : 4, blockindex : 5
threadindex : 5, blockindex : 5
threadindex : 6, blockindex : 5
threadindex : 0, blockindex : 6
threadindex : 1, blockindex : 6
threadindex : 2, blockindex : 6
threadindex : 3, blockindex : 6
threadindex : 4, blockindex : 6
threadindex : 5, blockindex : 6
threadindex : 6, blockindex : 6
threadindex : 0, blockindex : 3
threadindex : 1, blockindex : 3
threadindex : 2, blockindex : 3
threadindex : 3, blockindex : 3
threadindex : 4, blockindex : 3
threadindex : 5, blockindex : 3
threadindex : 6, blockindex : 3
As you can see above, the blocks do not appear to be running in parallel; they seem to run in a specific order.
My Environment :
  • Jetson TK1
  • Ubuntu 14.04(Jetpack 3.1)
  • CUDA version 6.5
Please note that I’m very beginner at CUDA
What would you have expected?
Something like ttttttttttthhhhhhhhhhhhhhhhrrrrrrrrrrrrrrrrrrrrrrrrr?
The printf output goes into buffers, all buffers are output separately.
You can use a chain of atomicAdds on global memory to test the parallel execution. Print out the returned value. Also your kernel probably is too short to see much of a parallel behaviour. Insert some __nanosleep to have more overlapping in time.
Hello. I expected random blocks because it is parallel :
132456/321465/654321
but the result is
123456/123456/123456
It is quite ordered value. It seems that block 2 ran after block 1, and block 3 ran after block 2.(not parallel)
For your understanding, I will rewrite the result I expected :
← I can’t understand why buffers would affect the order of printf() function outputs. Even if the output is buffered, it shouldn’t be related to the order in which the printf() functions are executed, from my point of view. Am I missing something?
I do not think there is a guarantee with printf. It is strictly a debugging tool.
Create an atomic variable and also print it (and increase it at the same time). Then you know the order of the increment.
In your example the kernel is loaded to 7 SMs (multiprocessors). On each of the SMs the threads are running in parallel and the SMs themselves are in parallel. So 49 threads run in parallel. The order you see has more to do with how Cuda printf works than with the execution time. You could also output the global timer in each thread.
