OK so the lines were corrected and the signals seems to be stable On J12 (CAM1) on the evaluation board. here are portions of my latest DT:
GST_DEBUG=4 gst-launch-1.0 -v v4l2src device=/dev/video0 do-timestamp=true ! video/x-raw,format=YUY2,width=1280,height=720,framerate=50/1 ! videoconvert ! xvimagesink sync=false -e
0:00:00.000197320 4165 0xaaaaeffd9600 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.16.3
0:00:00.000320556 4165 0xaaaaeffd9600 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000362478 4165 0xaaaaeffd9600 INFO GST_INIT gst.c:605:init_pre: Linux ubuntu-desktop 5.10.216-tegra #1 SMP PREEMPT Fri Sep 19 14:25:31 PDT 2025 aarch64
0:00:00.001056264 4165 0xaaaaeffd9600 INFO GST_INIT gstmessage.c:128:_priv_gst_message_initialize: init messages
0:00:00.002762504 4165 0xaaaaeffd9600 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.003521380 4165 0xaaaaeffd9600 INFO GST_PLUGIN_LOADING gstplugin.c:318:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.003833968 4165 0xaaaaeffd9600 INFO GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.003873425 4165 0xaaaaeffd9600 INFO GST_PLUGIN_LOADING gstplugin.c:228:gst_plugin_register_static: added static plugin “staticelements”, result: 1
0:00:00.003930356 4165 0xaaaaeffd9600 INFO GST_REGISTRY gstregistry.c:1733:ensure_current_registry: reading registry cache: /home/ubuntu/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.052990978 4165 0xaaaaeffd9600 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/ubuntu/.cache/gstreamer-1.0/registry.aarch64.bin in 0.048980 seconds
0:00:00.053271373 4165 0xaaaaeffd9600 INFO GST_REGISTRY gstregistry.c:1592:scan_and_update_registry: Validating plugins from registry cache: /home/ubuntu/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.059185868 4165 0xaaaaeffd9600 INFO GST_REGISTRY gstregistry.c:1691:scan_and_update_registry: Registry cache has not changed
0:00:00.059242382 4165 0xaaaaeffd9600 INFO GST_REGISTRY gstregistry.c:1768:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.059270607 4165 0xaaaaeffd9600 INFO GST_INIT gst.c:806:init_post: GLib runtime version: 2.64.6
0:00:00.059302128 4165 0xaaaaeffd9600 INFO GST_INIT gst.c:808:init_post: GLib headers version: 2.64.6
0:00:00.059327441 4165 0xaaaaeffd9600 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.059412149 4165 0xaaaaeffd9600 INFO GST_PIPELINE gstparse.c:336:gst_parse_launch_full: parsing pipeline description 'v4l2src device=/dev/video0 do-timestamp=true ! video/x-raw,format=YUY2,width=1280,height=720,framerate=50/1 ! videoconvert ! xvimagesink sync=false ’
0:00:00.067759856 4165 0xaaaaeffd9600 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so” loaded
0:00:00.067821266 4165 0xaaaaeffd9600 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element “v4l2src”
0:00:00.069814461 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:GstBaseSrc@0xaaaaf022e240 adding pad ‘src’
0:00:00.070638012 4165 0xaaaaeffd9600 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideoconvert.so” loaded
0:00:00.070682910 4165 0xaaaaeffd9600 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element “videoconvert”
0:00:00.071315286 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:GstBaseTransform@0xaaaaf0237340 adding pad ‘sink’
0:00:00.071378040 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:GstBaseTransform@0xaaaaf0237340 adding pad ‘src’
0:00:00.073916472 4165 0xaaaaeffd9600 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstxvimagesink.so” loaded
0:00:00.073963066 4165 0xaaaaeffd9600 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element “xvimagesink”
0:00:00.074454956 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:GstBaseSink@0xaaaaf022be00 adding pad ‘sink’
0:00:00.074568913 4165 0xaaaaeffd9600 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element “pipeline”
0:00:00.074892893 4165 0xaaaaeffd9600 INFO GST_PIPELINE grammar.y:648:gst_parse_perform_link: linking some pad of GstV4l2Src named v4l2src0 to some pad of GstVideoConvert named videoconvert0 (0/0) with caps “video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1”
0:00:00.076354452 4165 0xaaaaeffd9600 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin “/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so” loaded
0:00:00.076410870 4165 0xaaaaeffd9600 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element “capsfilter”
0:00:00.076646943 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:GstBaseTransform@0xaaaaf0248190 adding pad ‘sink’
0:00:00.076704001 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:GstBaseTransform@0xaaaaf0248190 adding pad ‘src’
0:00:00.076750915 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2090:gst_bin_get_state_func: getting state
0:00:00.076832422 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to NULL
0:00:00.076877032 4165 0xaaaaeffd9600 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.076922185 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element v4l2src0:(any) to element capsfilter0:sink
0:00:00.076954347 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.076984524 4165 0xaaaaeffd9600 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: v4l2src0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.077028173 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link v4l2src0:src and capsfilter0:sink
0:00:00.077080079 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:capsfilter0:src pad has no peer
0:00:00.077138001 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked v4l2src0:src and capsfilter0:sink, successful
0:00:00.077164883 4165 0xaaaaeffd9600 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.077188435 4165 0xaaaaeffd9600 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:v4l2src0:src Received event on flushing pad. Discarding
0:00:00.077238389 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element capsfilter0:src to element videoconvert0:(any)
0:00:00.077270006 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.077302744 4165 0xaaaaeffd9600 INFO GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link capsfilter0:src and videoconvert0:sink
0:00:00.077367674 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:videoconvert0:src pad has no peer
0:00:00.079738516 4165 0xaaaaeffd9600 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: capsfilter0 and videoconvert0 in same bin, no need for ghost pads
0:00:00.079794262 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link capsfilter0:src and videoconvert0:sink
0:00:00.079873145 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:videoconvert0:src pad has no peer
0:00:00.082150031 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked capsfilter0:src and videoconvert0:sink, successful
0:00:00.082187824 4165 0xaaaaeffd9600 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.082218609 4165 0xaaaaeffd9600 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:capsfilter0:src Received event on flushing pad. Discarding
0:00:00.082282964 4165 0xaaaaeffd9600 INFO GST_PIPELINE grammar.y:648:gst_parse_perform_link: linking some pad of GstVideoConvert named videoconvert0 to some pad of GstXvImageSink named xvimagesink0 (0/0) with caps “(NULL)”
0:00:00.082316757 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element videoconvert0:(any) to element xvimagesink0:(any)
0:00:00.082350678 4165 0xaaaaeffd9600 INFO GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link videoconvert0:src and xvimagesink0:sink
0:00:00.082565982 4165 0xaaaaeffd9600 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: videoconvert0 and xvimagesink0 in same bin, no need for ghost pads
0:00:00.082615680 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link videoconvert0:src and xvimagesink0:sink
0:00:00.082869930 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked videoconvert0:src and xvimagesink0:sink, successful
0:00:00.082897483 4165 0xaaaaeffd9600 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.082925516 4165 0xaaaaeffd9600 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:videoconvert0:src Received event on flushing pad. Discarding
Setting pipeline to PAUSED …
0:00:00.083079794 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.097178470 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to READY
0:00:00.097230056 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.097306251 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘xvimagesink0’ changed state to 2(READY) successfully
0:00:00.097367565 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.097399118 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to READY
0:00:00.097457552 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.097495986 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 2(READY) successfully
0:00:00.097531635 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.097565524 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to READY
0:00:00.097593653 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.097627831 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 2(READY) successfully
0:00:00.097655832 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current NULL pending VOID_PENDING, desired next READY
0:00:00.098161611 4165 0xaaaaeffd9600 INFO v4l2 v4l2_calls.c:587:gst_v4l2_open:v4l2src0:src Opened device ‘vi-output, it6616 1-0048’ (/dev/video0) successfully
0:00:00.098227469 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to READY
0:00:00.098259343 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.098326161 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘v4l2src0’ changed state to 2(READY) successfully
0:00:00.098369875 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2660:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.098398772 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.098480215 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2668:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:00:00.098535321 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.098612508 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2959:gst_bin_change_state_func: child ‘xvimagesink0’ is changing state asynchronously to PAUSED
0:00:00.098645213 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.098689983 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PAUSED
0:00:00.098719840 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.098760130 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 3(PAUSED) successfully
0:00:00.098795075 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.098854725 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PAUSED
0:00:00.098886502 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.098928040 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 3(PAUSED) successfully
0:00:00.098979242 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next PAUSED
0:00:00.099048972 4165 0xaaaaeffd9600 INFO basesrc gstbasesrc.c:1373:gst_base_src_do_seek: seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.099196402 4165 0xaaaaeffd9600 INFO task gsttask.c:460:gst_task_set_lock: setting stream lock 0xaaaaf02300e0 on task 0xaaaaf0259050
0:00:00.099229619 4165 0xaaaaeffd9600 INFO GST_PADS gstpad.c:6159:gst_pad_start_task:v4l2src0:src created task 0xaaaaf0259050
0:00:00.099416890 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PAUSED
0:00:00.099451292 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.099488189 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2995:gst_bin_change_state_func: child ‘v4l2src0’ changed state to 3(PAUSED) successfully without preroll
0:00:00.099543327 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PAUSED
0:00:00.099570560 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
Pipeline is live and does not need PREROLL …
0:00:00.099675524 4165 0xaaaaf0222de0 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad ‘sink’ in element “v4l2src0”
0:00:00.099967055 4165 0xaaaaf0222de0 INFO v4l2 gstv4l2object.c:1201:gst_v4l2_object_fill_format_list:v4l2src0:src got 2 format(s):
0:00:00.100014385 4165 0xaaaaf0222de0 INFO v4l2 gstv4l2object.c:1205:gst_v4l2_object_fill_format_list:v4l2src0:src YUYV
0:00:00.100059571 4165 0xaaaaf0222de0 INFO v4l2 gstv4l2object.c:1205:gst_v4l2_object_fill_format_list:v4l2src0:src YUYV
0:00:00.100331997 4165 0xaaaaf0222de0 INFO v4l2 gstv4l2object.c:4267:gst_v4l2_object_probe_caps:v4l2src0:src probed caps: video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1; video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1
Setting pipeline to PLAYING …
0:00:00.101084505 4165 0xaaaaeffd9600 INFO GST_EVENT gstevent.c:1449:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.101127835 4165 0xaaaaf0222de0 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
0:00:00.101160636 4165 0xaaaaeffd9600 INFO bin gstbin.c:2783:gst_bin_do_latency_func: configured latency of 0:00:00.000000000
0:00:00.101256096 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending PAUSED, desired next PLAYING
0:00:00.101287713 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2959:gst_bin_change_state_func: child ‘xvimagesink0’ is changing state asynchronously to PLAYING
0:00:00.101324738 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.101365156 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PLAYING
0:00:00.101412966 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.101469000 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 4(PLAYING) successfully
0:00:00.101459111 4165 0xaaaaf0222de0 INFO basetransform gstbasetransform.c:1317:gst_base_transform_setcaps: reuse caps
0:00:00.101546475 4165 0xaaaaf0222de0 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
0:00:00.101554731 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.101632686 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PLAYING
0:00:00.101706193 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.101789236 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 4(PLAYING) successfully
0:00:00.101834646 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PLAYING
0:00:00.101865527 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.101902392 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘v4l2src0’ changed state to 4(PLAYING) successfully
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
0:00:00.103513173 4165 0xaaaaf0222de0 INFO basetransform gstbasetransform.c:1317:gst_base_transform_setcaps: reuse caps
0:00:00.103856354 4165 0xaaaaf0222de0 INFO GST_EVENT gstevent.c:820:gst_event_new_caps: creating caps event video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0.GstPad:sink: caps = video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, framerate=(fraction)50/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
0:00:00.108479408 4165 0xaaaaf0222de0 INFO v4l2 gstv4l2object.c:2942:gst_v4l2_object_setup_pool:v4l2src0:src accessing buffers via mode 4
0:00:00.108969603 4165 0xaaaaf0222de0 INFO v4l2bufferpool gstv4l2bufferpool.c:557:gst_v4l2_buffer_pool_set_config:v4l2src0:pool:src increasing minimum buffers to 2
0:00:00.109007876 4165 0xaaaaf0222de0 INFO v4l2bufferpool gstv4l2bufferpool.c:570:gst_v4l2_buffer_pool_set_config:v4l2src0:pool:src reducing maximum buffers to 32
0:00:00.109155114 4165 0xaaaaf0222de0 INFO v4l2bufferpool gstv4l2bufferpool.c:570:gst_v4l2_buffer_pool_set_config:v4l2src0:pool:src reducing maximum buffers to 32
0:00:02.755193647 4165 0xaaaaf0222de0 WARN v4l2src gstv4l2src.c:914:gst_v4l2src_create: Timestamp does not correlate with any clock, ignoring driver timestamps
0:00:02.755365142 4165 0xaaaaf0222de0 INFO v4l2src gstv4l2src.c:960:gst_v4l2src_create: sync to 0:00:00.020000000 out ts 0:00:02.633993201
0:00:02.755525500 4165 0xaaaaf0222de0 INFO GST_EVENT gstevent.c:900:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:02.755712515 4165 0xaaaaf0222de0 INFO basesrc gstbasesrc.c:2962:gst_base_src_loop: marking pending DISCONT
0:00:02.786689509 4165 0xaaaaf0222de0 INFO GST_STATES gstbin.c:3430:bin_handle_async_done: setting state from PAUSED to PAUSED, pending PLAYING
0:00:02.786768136 4165 0xaaaaf0222de0 INFO GST_STATES gstbin.c:3452:bin_handle_async_done: continue state change, pending PLAYING
0:00:02.787666570 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:3248:gst_bin_continue_func: continue state change PAUSED to PLAYING, final PLAYING
0:00:02.788198623 4165 0xaaaaf0223180 INFO GST_EVENT gstevent.c:1449:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:02.788526891 4165 0xaaaaf0223180 INFO bin gstbin.c:2783:gst_bin_do_latency_func: configured latency of 0:00:00.000000000
0:00:02.788860824 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:02.789063104 4165 0xaaaaf0223180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PLAYING
0:00:02.789244647 4165 0xaaaaf0223180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:02.789690424 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘xvimagesink0’ changed state to 4(PLAYING) successfully
0:00:02.790113928 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:02.790158122 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2621:gst_bin_element_set_state: skipping transition from PLAYING to PLAYING
0:00:02.790348337 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 4(PLAYING) successfully
0:00:02.796032203 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:02.796076908 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2621:gst_bin_element_set_state: skipping transition from PLAYING to PLAYING
0:00:02.796114254 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 4(PLAYING) successfully
0:00:02.796150447 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:02.796181136 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2621:gst_bin_element_set_state: skipping transition from PLAYING to PLAYING
0:00:02.796212594 4165 0xaaaaf0223180 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘v4l2src0’ changed state to 4(PLAYING) successfully
0:00:02.797150678 4165 0xaaaaf0223180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PLAYING
0:00:02.797197271 4165 0xaaaaf0223180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:02.813810803 4165 0xaaaaf0222de0 INFO v4l2src gstv4l2src.c:960:gst_v4l2src_create: sync to 0:00:00.040000000 out ts 0:00:02.692773372
0:00:02.821966124 4165 0xaaaaf0222de0 INFO v4l2src gstv4l2src.c:960:gst_v4l2src_create: sync to 0:00:00.060000000 out ts 0:00:02.700956405
0:00:02.829089276 4165 0xaaaaf0222de0 INFO v4l2src gstv4l2src.c:960:gst_v4l2src_create: sync to 0:00:00.080000000 out ts 0:00:02.708079110
0:00:04.676515929 4165 0xaaaaf0222d20 WARN xvimagesink xvimagesink.c:554:gst_xv_image_sink_handle_xevents: error: Output window was closed
0:00:04.676757378 4165 0xaaaaf0222d20 INFO GST_ERROR_SYSTEM gstelement.c:2153:gst_element_message_full_with_details: posting message: Output window was closed
0:00:04.676994667 4165 0xaaaaf0222d20 INFO GST_ERROR_SYSTEM gstelement.c:2180:gst_element_message_full_with_details: posted error message: Output window was closed
ERROR: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Output window was closed
Additional debug info:
xvimagesink.c(554): gst_xv_image_sink_handle_xevents (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
0:00:05.570658352 4165 0xaaaaf0222de0 INFO v4l2src gstv4l2src.c:960:gst_v4l2src_create: sync to 0:00:00.100000000 out ts 0:00:05.449563254
0:00:05.571425646 4165 0xaaaaf0222de0 WARN v4l2src gstv4l2src.c:978:gst_v4l2src_create: lost frames detected: count = 18446744073709551612 - ts: 0:00:05.449563254
0:00:05.575071260 4165 0xaaaaf0222de0 WARN xvimagesink xvimagesink.c:1016:gst_xv_image_sink_show_frame: could not output image - no window
0:00:05.575192609 4165 0xaaaaf0222de0 INFO basesrc gstbasesrc.c:2981:gst_base_src_loop: pausing after gst_pad_push() = error
0:00:05.575258627 4165 0xaaaaf0222de0 WARN basesrc gstbasesrc.c:3072:gst_base_src_loop: error: Internal data stream error.
0:00:05.575294181 4165 0xaaaaf0222de0 WARN basesrc gstbasesrc.c:3072:gst_base_src_loop: error: streaming stopped, reason error (-5)
0:00:05.575366504 4165 0xaaaaf0222de0 INFO GST_ERROR_SYSTEM gstelement.c:2153:gst_element_message_full_with_details: posting message: Internal data stream error.
0:00:05.575466956 4165 0xaaaaf0222de0 INFO GST_ERROR_SYSTEM gstelement.c:2180:gst_element_message_full_with_details: posted error message: Internal data stream error.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
0:00:05.575812761 4165 0xaaaaf0222de0 INFO task gsttask.c:312:gst_task_func:v4l2src0:src Task going to paused
Got EOS from element “pipeline0”.
EOS received - stopping pipeline…
Execution ended after 0:00:05.474204364
Setting pipeline to NULL …
0:00:05.576306572 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:05.576369647 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PAUSED
0:00:05.576415825 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:05.576508692 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘xvimagesink0’ changed state to 3(PAUSED) successfully
0:00:05.576574295 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:05.576653658 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PAUSED
0:00:05.576707324 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:05.576798400 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 3(PAUSED) successfully
0:00:05.576900772 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:05.576960710 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PAUSED
0:00:05.577040521 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:05.577117996 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 3(PAUSED) successfully
0:00:05.577211216 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:05.577279794 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to PAUSED
0:00:05.577330292 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:05.577400855 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2995:gst_bin_change_state_func: child ‘v4l2src0’ changed state to 3(PAUSED) successfully without preroll
0:00:05.577478010 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2660:gst_element_continue_state: committing state from PLAYING to PAUSED, pending NULL, next READY
0:00:05.577521596 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PLAYING to PAUSED (NULL pending)
0:00:05.577614399 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2668:gst_element_continue_state: continue state change PAUSED to READY, final NULL
0:00:05.577692931 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:00:05.577876810 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to READY
0:00:05.577924620 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:05.578076978 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘xvimagesink0’ changed state to 2(READY) successfully
0:00:05.578144948 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:00:05.578279289 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to READY
0:00:05.578332668 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:05.578430239 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 2(READY) successfully
0:00:05.578492994 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current PAUSED pending VOID_PENDING, desired next READY
0:00:05.578608710 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to READY
0:00:05.578669769 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:05.578737579 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 2(READY) successfully
0:00:05.579031287 4165 0xaaaaf0222de0 INFO task gsttask.c:314:gst_task_func:v4l2src0:src Task resume from paused
0:00:08.146955390 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to READY
0:00:08.147089443 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:08.147177735 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘v4l2src0’ changed state to 2(READY) successfully
0:00:08.147245802 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2660:gst_element_continue_state: committing state from PAUSED to READY, pending NULL, next NULL
0:00:08.147293291 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed PAUSED to READY (NULL pending)
0:00:08.147402160 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2668:gst_element_continue_state: continue state change READY to NULL, final NULL
0:00:08.147496148 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:08.194776526 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to NULL
0:00:08.194872498 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:08.194960886 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘xvimagesink0’ changed state to 1(NULL) successfully
0:00:08.195079738 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:08.195143837 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to NULL
0:00:08.195187679 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:08.195249697 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘videoconvert0’ changed state to 1(NULL) successfully
0:00:08.195335717 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:08.195392423 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to NULL
0:00:08.195436041 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:08.195509964 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘capsfilter0’ changed state to 1(NULL) successfully
0:00:08.195561902 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state: current READY pending VOID_PENDING, desired next NULL
0:00:08.195668498 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to NULL
0:00:08.195715348 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:08.195777558 4165 0xaaaaeffd9600 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func: child ‘v4l2src0’ changed state to 1(NULL) successfully
0:00:08.195923228 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2688:gst_element_continue_state: completed state change to NULL
0:00:08.195969086 4165 0xaaaaeffd9600 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed: notifying about state-changed READY to NULL (VOID_PENDING pending)
Freeing pipeline …
0:00:08.196092035 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstpad.c:2132:gst_pad_unlink: unlinking v4l2src0:src(0xaaaaf0230070) and capsfilter0:sink(0xaaaaf02309b0)
0:00:08.196158981 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstpad.c:2187:gst_pad_unlink: unlinked v4l2src0:src and capsfilter0:sink
0:00:08.196223048 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstpad.c:2132:gst_pad_unlink: unlinking capsfilter0:src(0xaaaaf0230c00) and videoconvert0:sink(0xaaaaf02302c0)
0:00:08.196279210 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstpad.c:2187:gst_pad_unlink: unlinked capsfilter0:src and videoconvert0:sink
0:00:08.196330476 4165 0xaaaaeffd9600 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “capsfilter0”
0:00:08.196417648 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3264:gst_element_dispose: 0xaaaaf0248190 dispose
0:00:08.196461233 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:787:gst_element_remove_pad: removing pad ‘sink’
0:00:08.196580086 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:787:gst_element_remove_pad: removing pad ‘src’
0:00:08.196633816 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3309:gst_element_dispose: 0xaaaaf0248190 parent class dispose
0:00:08.196676730 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3341:gst_element_finalize: 0xaaaaf0248190 finalize
0:00:08.196753341 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3346:gst_element_finalize: 0xaaaaf0248190 finalize parent
0:00:08.196852737 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstpad.c:2132:gst_pad_unlink: unlinking videoconvert0:src(0xaaaaf0230510) and xvimagesink0:sink(0xaaaaf0230760)
0:00:08.196911939 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstpad.c:2187:gst_pad_unlink: unlinked videoconvert0:src and xvimagesink0:sink
0:00:08.196970118 4165 0xaaaaeffd9600 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “xvimagesink0”
0:00:08.197064233 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3264:gst_element_dispose: 0xaaaaf022be00 dispose
0:00:08.197108203 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:787:gst_element_remove_pad: removing pad ‘sink’
0:00:08.197154509 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3309:gst_element_dispose: 0xaaaaf022be00 parent class dispose
0:00:08.197200943 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3341:gst_element_finalize: 0xaaaaf022be00 finalize
0:00:08.197240944 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3346:gst_element_finalize: 0xaaaaf022be00 finalize parent
0:00:08.197318644 4165 0xaaaaeffd9600 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “videoconvert0”
0:00:08.197378582 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3264:gst_element_dispose: 0xaaaaf0237340 dispose
0:00:08.197420120 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:787:gst_element_remove_pad: removing pad ‘sink’
0:00:08.197469690 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:787:gst_element_remove_pad: removing pad ‘src’
0:00:08.197522268 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3309:gst_element_dispose: 0xaaaaf0237340 parent class dispose
0:00:08.197590622 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3341:gst_element_finalize: 0xaaaaf0237340 finalize
0:00:08.197639264 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3346:gst_element_finalize: 0xaaaaf0237340 finalize parent
0:00:08.197694243 4165 0xaaaaeffd9600 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func: removed child “v4l2src0”
0:00:08.197751429 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3264:gst_element_dispose: 0xaaaaf022e240 dispose
0:00:08.197792422 4165 0xaaaaeffd9600 INFO GST_ELEMENT_PADS gstelement.c:787:gst_element_remove_pad: removing pad ‘src’
0:00:08.197842888 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3309:gst_element_dispose: 0xaaaaf022e240 parent class dispose
0:00:08.197886986 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3341:gst_element_finalize: 0xaaaaf022e240 finalize
0:00:08.197926412 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3346:gst_element_finalize: 0xaaaaf022e240 finalize parent
0:00:08.197966733 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3264:gst_element_dispose: 0xaaaaf0240040 dispose
0:00:08.198234936 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3309:gst_element_dispose: 0xaaaaf0240040 parent class dispose
0:00:08.198277978 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3341:gst_element_finalize: 0xaaaaf0240040 finalize
0:00:08.198315771 4165 0xaaaaeffd9600 INFO GST_REFCOUNTING gstelement.c:3346:gst_element_finalize: 0xaaaaf0240040 finalize parent
0:00:08.198350013 4165 0xaaaaeffd9600 INFO GST_INIT gst.c:1083:gst_deinit: deinitializing GStreamer
0:00:08.205205134 4165 0xaaaaeffd9600 INFO GST_INIT gst.c:1232:gst_deinit: deinitialized GStreamer
getting the green screen…could you please point me to what can be debugged to understand what am I missing here?
