i enabled iwlwifi driver for Intel 9260 and setup AP and everything is working.
When i try to transfer big files (with ssh/scp) the max speed is about 3MB/s.
I tried to disable power save but i can’t :
root@jetson-nano:~# iw dev wlan0 set power_save off
command failed: Operation not supported (-95)
root@jetson-nano:~# iw dev wlan0 get power_save
Power save: on
i added the patch to dhd_linux.c :
+ dhd_slpauto_config(dhd, 0);
DHD_ERROR(("Firmware up: op_mode=0x%04x, MAC="MACDBG"\n",
dhd->op_mode, MAC2STRDBG(dhd->mac.octet)));
/* Set Country code */
Nothing changed after the patch, any idea about this?
This is the test I did on my jetson nano with Intel 8265 NGW.
Could you share more information? the singal, etc will impact the performance.
Have you test within the local env?
root@jetson-nano:~# iw dev wlan0 set power_save on
root@jetson-nano:~# iw dev wlan0 get power_save on
Power save: on
Power save: off
root@jetson-nano:~#
root@jetson-nano:/home/dlinano# iw dev wlan0 link
Connected to b4:de:31:fb:b9:8e (on wlan0)
SSID: NV_VISITOR
freq: 5280
RX: 1308218 bytes (535 packets)
TX: 39794 bytes (308 packets)
signal: -68 dBm
tx bitrate: 650.0 MBit/s VHT-MCS 7 80MHz short GI VHT-NSS 2
bss flags: short-slot-time
dtim period: 1
beacon int: 100
i can now set power save to off after stopping Hostapd deamon.
also the signal level is not good (antenna not installed), bellow information my PC connected to the setup AP:
IEEE 802.11 ESSID:"test"
Mode:Managed Frequency:2.412 GHz Access Point: A0:51:0B:5A:F1:7C
Bit Rate=1 Mb/s Tx-Power=20 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=34/70 Signal level=-76 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:29 Missed beacon:0
* test Infra 1 54 Mbit/s 50 ▂▄__ --
The Nano Kit is near my PC (5cm) so no need to have antenna, right?
Or it’s linked to the use of 802.11b low bandwidth?
In order to keep a good connection the speed will drop to 5.5Mbps、2Mbps、1Mbps or lower.
You can test with a wireless router with a antenna attached to evaluate the performance.
Mostly the signal of the AP is not good enough and the antenna is always required to keep a good performance.
