I have an adaptor that has a TI TCAN4550 CAN controller that interfaces to the Nano using SPI.
The upper layer will be J1939.
There are sources for both of the above in the Linux source tree on GitHub, but not in the public sources for the Nano.
I have attempted to build the kernel with the added sources.
I am able to configure them with menuconfig, but they don’t appear in the output.
I may have not got the makefiles correctly setup.
I included the source in the public sources and I changed the configuration to where it appeared menuconfig allowed me to enable them.
The build completed, but I didn’t see any J1939/CAN in the output.
There wasn’t any errors either, which is somewhat suspect.
I may have not got the makefile tree correct.
Did you add the file config in Kconfig? when the menuconfig saves, .config gets created. this .config should be finally copied to tegra_defconfig. Then after kernel build, you will be able to see J1939. Please also search for how to add a kernel driver in google for better understanding.
