J90 Motherboard - I2C not working
I’m trying to connect one I2C device to the J90 Motherboard. When I connect the device to the nvidia developper kit motherboard it’s work fine. But when I connect the device to the J90 motherboard, the device lights up but is not detected by the Jetson.
Is someone has a idea of the problem ? Maybe there is different driver for the GPIO of the J90 ?
corresponding thread found: https://devtalk.nvidia.com/default/topic/1015720/when-i-power-up-the-j90-the-fan-run-at-maximum-speed-and-nothing-happens/?offset=2
I would contact the manufacturer.
for j100 they have some pdf file: http://www.unipos.net/download/J100_data_%20sheet1.4.pdf
for j90 they have : https://auvidea.com/download/manual/J90/J90_technical_reference_1.2.pdf
As mentioned by other replies you probably need to ask the manufacturer. Odds though are very high they will suggest a device tree change. If the manufacturer has any sample device tree files I’d start there.
For contacting the support you may use: https://auvidea.com/my-tickets/
It seems that there takes place a registration which allows to create tickets.
I sent a e-mail to Auvidea. On the website there is only a patch for USB.
https://auvidea.com/firmware/
It seems that they have sample dtb file and provide instructions for device tree modification : https://auvidea.com/download/firmware/TX2/TX2_USB2_sample_dtb.tar.gz
USB 2.0: please apply a patch to the device tree to enable USB 2.0
Please replace the line: ‘vbus-2-supply = <0x99>;’
by the following line: ‘vbus-2-supply = <0x19>;’
However for USB 3.0 they say:
USB 3.0: please download the USB3.0 patch[<a target='_blank' rel='noopener noreferrer' href='https://auvidea.com/download/firmware/TX2/ChangesTX2J140.tar.gz'>https://auvidea.com/download/firmware/TX2/ChangesTX2J140.tar.gz</a>] for the TX2 and the Auvidea carrier boards
But this is only for USB ?
As far as I can see this is for usb. Hopefully, they will respond with some instructions on requests and tickets. You may point them to the devtalk thread aw well.
