JACKSON POWER ON
Hellow
Should the power LED on the JACKSON nano turn on when I connect the power without inserting the SD CARD into the jackson nano?
The JACKSON nano power LED sometimes comes on and sometimes doesn’t, regardless of the operation.
The same thing happens when an SD card is inserted.
Hi bangjongin,
Are you using the devkit or custom board for Jetson Nano?
It should turn on when it is powered.
Please check the full serial console log for detailed information.
I am using NVIDIA Jetson Nano Developer Kit A02.
Do I need log even though I did not connect SD CARD?
What’s the Jatpack version in use?
Are you using SD or eMMC module for Jetson Nano?
Please insert SD card and refer to the following instruction to capture serial console log.
Jetson Nano & NX Style - Serial Debug Console - JetsonHacks
