MOD_SHUTDOWN_N is output from module, a way for the module to communicate to the baseboard that it needs to shut down right away (either due to thermal or SW shutdown)
please update your DG typo in table 5-1 from input to output.
the usecase is that JAO module will send this signal to carrier board (base board) and let carrier board to shut down when JAO module over thermal ?
Because JAO module also have VCOMP_ALERT_N; THERM_ALERT_N; SYSTEM_OC_N and MODULE_SHDN_N
signal , where i can find the detail description for those signal and how to handle it in our SW.
