Hi, I am trying to execute the Jarvis ASR feature using the quickstart guide Quick Start Guide — NVIDIA Riva. This works well for the sample wav file provided but fails for wav files larger than 4MB with this error:
Loading eval dataset…
filename: /data/newsvideo1_mono.wav
Done loading 1 files
RPC failed: Received message larger than max (11636842 vs. 4194304)
Done processing 1 responses
Some requests failed to complete properly, not printing performance stats
I managed to increase the size limit for streaming asr client by adding this line
in “jarvis_streaming_asr_client.py” inside the docker container.
But this only works for streaming asr, I was wondering if there is a way to increase the size limit for batch mode as well and perhaps a better solution than the one mentioned above.
Any help would be appreciated.
