Hi, I am trying to install Jarvis but I came across some errors. I am using MacOS. My API key is saved as an environment variable (I had to do this to make jarvis_init.sh
run, otherwise I keep getting an invalid API key error). However, I am facing the following error messages:
> Pulling Jarvis Speech Server images.
> Pulling nvcr.io/nvidia/jarvis/jarvis-speech:1.0.0-b.2-server. This may take some time...
unauthorized: authentication required
> Attempt 1 out of 3 failed
Lastly, what is the difference between doing this compared to running the following command?
pip install jarvis_api-1.0.0b2-py3-none-any.whl
