Jatpack 5.0.0/5.0.1 compilation errors
There are few simple compilation errors on the Jetpack 5.0.0/5.0.1 Developer Preview that can easily fix for next version:
  1. One compilation issue, and possible solution is as described here:
on
Linux_for_Tegra/sources/kernel/kernel-5.10/arch/arm64/boot/dts/Makefile
change
DTC_INCLUDE += $(tegra-dtstree)/platform/t23x/common/kernel-dts
To
Described here too:
  1. Simple missing of quotation mark here:
on
Linux_for_Tegra/sources/kernel/nvidia/drivers/misc/Kconfig
source “drivers/misc/nvscic2c-pcie/Kconfig”
  1. Missing include as described here:
In file included from /home/netipc/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/sources/kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/ether_linux.c:19:
/home/netipc/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/sources/kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/ether_linux.h:62:10: fatal error: osi_core.h: No such file or directory
62 | #include <osi_core.h>
I am not sure what is the best way to solve that. I hacked the compilation by first compile the code as is. It stopped due the missing osi_core.h. and then recompile, with the symlink.
seems that ship form is more active:
