Jenkins Build
I’m creating a Jenkins job to build and compile my teams code. Within our code we’re using the deepstream plugin that is integrated with CUDA. The current workflow in the CI/CD pipeline is as follows:
  • Pull code from git hub
  • Create docker container and do all the building and compiling within that container
  • Extract executable
  • Containerize executable and push to docker repo
The problem is that when building the code . I’m getting the following error
/opt/nvidia/deepstream/deepstream-4.0/lib/libnvdsgst_meta.so: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
I’ve tried to use nvidia docker but I need to be connected nivida driver. I’m pretty much stuck and I’m open to all possible suggestions/designs.
This looks like an architecture issue.
It’s recommended to check if the executable from the GitHub can be run on the ARM system or not first.
