• DeepStream Version: 5.1
• JetPack Version: 4.5(valid for Jetson only)
• TensorRT Version
Docker images: nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples
Triton server 2.10 Releases · triton-inference-server/server · GitHub
All samples works fine when I run deepstream 5.1 with triton 2.5 (default version in above container)
But above container doesn’t support ONNX runtime so I did update to triton 2.10 (Releases · triton-inference-server/server · GitHub)
All samples are down with same error when I run deepstream-app -c <any-config-file.txt>
error: Input or ouput layers are empty.
Any idea to fix it? Thank you so much.
