While trying to run a deepstream docker image , it showed this error
error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: nvml error: driver not loaded: unknown.
When i run nvidia-smi i get this output
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
How can i reset the graphic drivers for the jetson nano ?
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
Can you help provide the below information?
Jetpack version
How your nvidia-docker is installed?
Command used to start docker
Please be noted that there is no nvidia-smi command in nano.
