Jeston Orin Dev-kit 64G Failing flash when nmve is selected
I am trying to flash Jetson Orin Dev-kit 64G using nvme but it is failing.
There is no problem with flashing it using EMMC.
Here are the logs
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2024-08-01_11-07-45.zip (469.8 KB)
Please disable every firewall setting on your host PC. Flashing nvme by using initrd flash tool requires to mount from NFS server.
