I use Jetson Orin NX 16GB modules and the Jetson Xavier NX Developer Kit carrier board.
When I try to backup my system, it doesn’t work and the backup gets stuck.
My jetpak version is 5.1.
The package used is Jetson_Linux_R35.2.1_aarch64.tbz2.
orin-nx-overlay-35.2.1.tbz2, Tegra_Linux_Sample-Root-Filesystem_R35.2.1_aarch64.tbz2
Commands used:
$ mkdir workspace
$ tar -xf Jetson_Linux_R35.2.1_aarch64.tbz2
$ tar -xf orin-nx-overlay-35.2.1.tbz2
$ cd Linux_for_Tegra/rootfs/
$ sudo tar -xpf ../../ Tegra_Linux_Sample-Root-Filesystem_R35.2.1_aarch64.tbz2
$ cd ..
$ sudo ./apply_binaries.sh
$ sudo ./flash.sh -k APP -G backup.img jetson-orin-nx-devkit-16gb mmcblk0p1
Terminal print:
# L4T BSP Information:
# R35 , REVISION: 2.1
# User release: 0.0
# Target Board Information:
# Name: jetson-orin-nx-devkit-16gb, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/data/jetson/orin/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
[ 0.0128 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0137 ] File rcm_state open failed
[ 0.0141 ] ERROR: failed to read rcm_state
[ 0.0141 ]
[ 0.0149 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0152 ] Assuming zero filled SBK key
[ 0.0147 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0205 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0306 ] Parsing partition layout
[ 0.0317 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0338 ] Kernel DTB used: None
[ 0.0338 ] WARNING: dce base dtb is not provided
[ 0.0338 ] Parsing partition layout
[ 0.0349 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0361 ] Creating list of images to be signed
[ 0.0371 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0381 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0391 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0394 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0449 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0460 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0512 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0515 ] adding BCH for mb2_t234_aligned.bin
[ 0.0544 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0678 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0681 ] adding BCH for mb2_t234_aligned.bin
[ 0.0836 ] Filling MB1 storage info
[ 0.0836 ] Parsing dev params for multi chains
[ 0.0897 ] Generating br-bct
[ 0.0908 ] Updating dev and MSS params in BR BCT
[ 0.0908 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0921 ] Updating bl info
[ 0.0931 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0940 ] WARNING: boot chain is not completed. set to 0
[ 0.0947 ] Generating signatures
[ 0.0955 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0958 ] Assuming zero filled SBK key
[ 0.1096 ] Warning: pub_key.key is not found
[ 0.1092 ] Parsing dev params for multi chains
[ 0.1092 ] Generating br-bct
[ 0.1100 ] Updating dev and MSS params in BR BCT
[ 0.1101 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1111 ] Updating bl info
[ 0.1119 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1127 ] WARNING: boot chain is not completed. set to 0
[ 0.1136 ] Get Signed section of bct
[ 0.1145 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1154 ] Signing BCT
[ 0.1162 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1164 ] Assuming zero filled SBK key
[ 0.1190 ] Sha saved in br_bct_BR.sha
[ 0.1195 ] Warning: pub_key.key is not found
[ 0.1188 ] Updating BCT with signature
[ 0.1197 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1205 ] Offset :4608 Len :3584
[ 0.1209 ] Generating SHA2 Hash
[ 0.1217 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1219 ] Assuming zero filled SBK key
[ 0.1220 ] Assuming zero filled SBK key
[ 0.1248 ] Sha saved in br_bct_BR.sha
[ 0.1246 ] Updating BCT with SHA2 Hash
[ 0.1255 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1263 ] Offset :4608 Len :3584
[ 0.1266 ] Offset :68 Len :8124
[ 0.1268 ] Generating coldboot mb1-bct
[ 0.1277 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1284 ] MB1-BCT version: 0.9
[ 0.1286 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1291 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1294 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1298 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1301 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1301 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 0.1301 ] ERROR: /misc/vmon/vdd_cpu/int/ is not supported
[ 0.1301 ]
[ 0.1302 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1302 ] Added Platform Config 9 data with size :- 100
[ 0.1302 ]
[ 0.1302 ] Updating mb1-bct with firmware information
[ 0.1310 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1332 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1352 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1361 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1379 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1381 ] Assuming zero filled SBK key
[ 0.1401 ] Warning: pub_key.key is not found
[ 0.1405 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1421 ] Generating recovery mb1-bct
[ 0.1430 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1439 ] MB1-BCT version: 0.9
[ 0.1440 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1445 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1449 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1452 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1456 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1456 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 0.1456 ] ERROR: /misc/vmon/vdd_cpu/int/ is not supported
[ 0.1456 ]
[ 0.1456 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1456 ] Added Platform Config 9 data with size :- 100
[ 0.1456 ]
[ 0.1457 ] Updating mb1-bct with firmware information
[ 0.1465 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1486 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1507 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1516 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1533 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1535 ] Assuming zero filled SBK key
[ 0.1555 ] Warning: pub_key.key is not found
[ 0.1559 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1576 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1576 ] Copying signatures
[ 0.1586 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1657 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1659 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1659 ] Boot Rom communication
[ 0.1669 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1680 ] BR_CID: 0x80012344705DD1903C0000000BFF0080
[ 0.1947 ] Sending bct_br
[ 0.2383 ] Sending mb1
[ 0.2392 ] Sending psc_bl1
[ 0.2483 ] Sending bct_mb1
[ 0.2541 ] Boot Rom communication completed
[ 0.2580 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.2619 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.2637 ] adding BCH for applet_t234_aligned.bin
[ 0.2783 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2785 ] Assuming zero filled SBK key
[ 0.2806 ] Warning: pub_key.key is not found
[ 0.2809 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.2826 ] Sending mb2_applet...
[ 0.2834 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.2842 ] BL: version 0.28.0.0-t234-54845784-ec016368 last_boot_error: 0
[ 0.4506 ] Sending applet
[ 0.5547 ] completed
[ 0.5573 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.5599 ] MB2 Applet version 01.00.0000
[ 0.7339 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7367 ] MB2 Applet version 01.00.0000
[ 0.7683 ] Retrieving board information
[ 0.7714 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.7727 ] MB2 Applet version 01.00.0000
[ 0.8173 ] Saved platform info in chip_info.bin
[ 0.8227 ] Chip minor revision: 1
[ 0.8233 ] Bootrom revision: 0x7
[ 0.8233 ] Ram code: 0x0
[ 0.8233 ] Chip sku: 0xd3
[ 0.8233 ] Chip Sample: prod
[ 0.8233 ]
[ 0.8241 ] Retrieving EEPROM data
[ 0.8242 ] tegrarcm_v2 --oem platformdetails eeprom cvm /data/jetson/orin/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.8263 ] MB2 Applet version 01.00.0000
[ 0.8572 ] Saved platform info in /data/jetson/orin/Linux_for_Tegra/bootloader/cvm.bin
[ 0.8935 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8962 ] MB2 Applet version 01.00.0000
[ 0.9275 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.9295 ] MB2 Applet version 01.00.0000
[ 0.9773 ] Dumping customer Info
[ 0.9804 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 0.9829 ] MB2 Applet version 01.00.0000
[ 1.0294 ] Saved bct in tmp.bct
[ 1.0399 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /data/jetson/orin/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 1.0420 ] C[ 1.0424 ] ustomer data saved in /data/jetson/orin/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 1.0425 ] Rebooting to recovery mode
[ 1.0438 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 1.0752 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.0772 ] MB2 Applet version 01.00.0000
[ 1.1213 ] Booting to recovery mode
[ 1.1243 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 1.1268 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0000) revision(G.3)
Chip SKU(00:00:00:D3) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
copying bctfile(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-sdram-l4t.dts)... done.
copying pinmux_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
copying dev_params(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/data/jetson/orin/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/data/jetson/orin/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/data/jetson/orin/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/data/jetson/orin/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/data/jetson/orin/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/data/jetson/orin/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Existing sosfile(/data/jetson/orin/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/data/jetson/orin/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/data/jetson/orin/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/data/jetson/orin/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/data/jetson/orin/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/data/jetson/orin/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/data/jetson/orin/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/data/jetson/orin/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/data/jetson/orin/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/data/jetson/orin/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/data/jetson/orin/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3767-0000-a02-3509-a02.dtb)... done.
Existing scefile(/data/jetson/orin/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/data/jetson/orin/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/data/jetson/orin/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/data/jetson/orin/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/data/jetson/orin/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/data/jetson/orin/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/data/jetson/orin/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/data/jetson/orin/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3768-0000-a0.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/data/jetson/orin/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 1.14246 s, 58.7 MB/s
Sync'ing esp.img ... done.
copying tbcdtbfile(/data/jetson/orin/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3768-0000-a0.dtb)... done.
copying cfgfile(/data/jetson/orin/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sd.xml) to flash.xml... done.
Existing flashapp(/data/jetson/orin/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Reading [APP] and storing to /data/jetson/orin/Linux_for_Tegra/santachi.img ***
copying overlay_dtb(/data/jetson/orin/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
./tegraflash.py --bl uefi_jetson_with_dtb.bin --chip 0x23 --applet mb1_t234_prod.bin --sdram_config tegra234-p3767-0000-sdram-l4t.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --cfg flash.xml --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo, --bldtb tegra234-p3767-0000-p3768-0000-a0.dtb --concat_cpubl_bldtb --cpubl uefi_jetson.bin --cmd "read APP /data/jetson/orin/Linux_for_Tegra/santachi.img" --bct_backup --boot_chain A
version 1.0.0
[ 0.0141 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[ 0.0197 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0257 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[ 0.0315 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[ 0.0385 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0483 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[ 0.0601 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[ 0.0653 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[ 0.0712 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[ 0.0777 ] Pre-processing config: tegra234-mb2-bct-scr-p3767-0000.dts
[ 0.5225 ] Pre-processing config: tegra234-p3767-0000-sdram-l4t.dts
[ 2.1732 ] Pre-processing config: tegra234-p3767-0000-wb0sdram-l4t.dts
[ 3.8254 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 3.8265 ] File rcm_state open failed
[ 3.8265 ] ERROR: failed to read rcm_state
[ 3.8265 ]
[ 3.8273 ] tegrasign_v3.py --key None --getmode mode.txt
[ 3.8276 ] Assuming zero filled SBK key
[ 3.8439 ] Parsing partition layout
[ 3.8454 ] tegraparser_v2 --pt flash.xml.tmp
[ 3.8539 ] Change tegra234-bpmp-3767-0000-a02-3509-a02.dtb to tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
[ 3.8540 ] Change tegra234-bpmp-3767-0000-a02-3509-a02.dtb to tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
[ 3.8913 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_tmp.dtb
[ 4.3704 ] Concatenating L4TConfiguration.dtbo to tegra234-p3767-0000-p3768-0000-a0_with_odm.dtb
[ 4.3706 ] Concatenating bl dtb to cpubl binary
[ 4.3739 ] MB2 binary: mb2_t234.bin
[ 4.3739 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[ 4.3842 ] Generating coldboot mb2-bct
[ 4.3842 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 4.3853 ] WARNING: unknown property 'tfc_version'
[ 4.3867 ] WARNING: unknown property 'addr_header_version'
[ 4.3974 ] Updating mb2-bct with storage information
[ 4.3985 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 4.4000 ] Concatenating mb2-bct to mb2 binary
[ 4.4000 ] mb2_bin_file = mb2_t234.bin
[ 4.4000 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 4.4043 ] DCE binary: display-t234-dce.bin
[ 4.4043 ] Kernel DTB used: kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
[ 4.4044 ] Concatenating kernel-dtb to dce-fw binary
[ 4.4044 ] dce_bin = display-t234-dce.bin
[ 4.4044 ] kernel_dtb = kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
[ 4.4044 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0.bin
[ 4.4112 ] Update display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0.bin to dce_fw partitions
[ 4.4139 ] Parsing partition layout
[ 4.4151 ] tegraparser_v2 --pt flash.xml.tmp
[ 4.4168 ] Creating list of images to be signed
[ 4.4179 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 4.4189 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 4.4199 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 4.4202 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 4.4247 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 4.4250 ] Header already present for nvdec_t234_prod_aligned.fw
[ 4.4277 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 4.4336 ] adding BCH for xusb_t234_prod_aligned.bin
[ 4.4480 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 4.4553 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 4.4725 ] Header already present for pscfw_t234_prod_aligned.bin
[ 4.4775 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 4.4839 ] Header already present for sc7_t234_prod.bin
[ 4.4872 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 4.4903 ] adding BCH for mb2rf_t234_aligned.bin
[ 4.4924 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 4.5028 ] adding BCH for tos-optee_t234_aligned.img
[ 4.6063 ] adding BCH for eks_t234_aligned.img
[ 4.6403 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin
[ 4.8065 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin, ratio = 7%
[ 4.8257 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned_blob_w_bin_aligned.bin
[ 4.8424 ] adding BCH for spe_t234_aligned.bin
[ 4.8549 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 4.8641 ] adding BCH for adsp-fw_aligned.bin
[ 4.8818 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 4.8952 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 4.8955 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 4.9001 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 4.9004 ] Header already present for nvdec_t234_prod_aligned.fw
[ 4.9028 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 4.9085 ] adding BCH for xusb_t234_prod_aligned.bin
[ 4.9227 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 4.9302 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 4.9476 ] Header already present for pscfw_t234_prod_aligned.bin
[ 4.9527 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 4.9593 ] Header already present for sc7_t234_prod.bin
[ 4.9626 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 4.9984 ] adding BCH for mb2rf_t234_aligned.bin
[ 5.0025 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 5.0170 ] adding BCH for tos-optee_t234_aligned.img
[ 5.1217 ] adding BCH for eks_t234_aligned.img
[ 5.1560 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin
[ 5.5337 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin, ratio = 7%
[ 5.5529 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned_blob_w_bin_aligned.bin
[ 5.5697 ] adding BCH for spe_t234_aligned.bin
[ 5.5821 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 5.5915 ] adding BCH for adsp-fw_aligned.bin
[ 5.6226 ] Filling MB1 storage info
[ 5.6227 ] Parsing dev params for multi chains
[ 5.6285 ] Generating br-bct
[ 5.6296 ] Updating dev and MSS params in BR BCT
[ 5.6297 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 5.7348 ] Updating bl info
[ 5.7359 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 5.7436 ] Generating br-bct
[ 5.7447 ] Updating dev and MSS params in BR BCT
[ 5.7448 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 5.8497 ] Updating bl info
[ 5.8509 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 5.8526 ] Generating BCT backup image
[ 5.8527 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 5.8538 ] 32768+0 records in
[ 5.9125 ] 32768+0 records out
[ 5.9125 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0580667 s, 564 kB/s
[ 5.9126 ]
[ 5.9126 ] Concatenating BCT for chain A to bct_backup.img
[ 5.9126 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 5.9135 ] 8192+0 records in
[ 5.9255 ] 8192+0 records out
[ 5.9256 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0116614 s, 702 kB/s
[ 5.9256 ]
[ 5.9256 ] Concatenating BCT for chain B to bct_backup.img
[ 5.9256 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 5.9266 ] 8192+0 records in
[ 5.9388 ] 8192+0 records out
[ 5.9388 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0118307 s, 692 kB/s
[ 5.9388 ]
[ 5.9388 ] Generating signatures
[ 5.9396 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.9399 ] Assuming zero filled SBK key
[ 6.3023 ] Warning: pub_key.key is not found
[ 6.3082 ] Parsing dev params for multi chains
[ 6.3082 ] Generating br-bct
[ 6.3092 ] Updating dev and MSS params in BR BCT
[ 6.3094 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.4120 ] Updating bl info
[ 6.4130 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.4153 ] Get Signed section of bct
[ 6.4163 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 6.4177 ] Signing BCT
[ 6.4184 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.4187 ] Assuming zero filled SBK key
[ 6.4219 ] Sha saved in br_bct_BR.sha
[ 6.4224 ] Warning: pub_key.key is not found
[ 6.4217 ] Updating BCT with signature
[ 6.4228 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 6.4237 ] Offset :4608 Len :3584
[ 6.4240 ] Generating SHA2 Hash
[ 6.4248 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 6.4250 ] Assuming zero filled SBK key
[ 6.4284 ] Sha saved in br_bct_BR.sha
[ 6.4282 ] Updating BCT with SHA2 Hash
[ 6.4293 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 6.4305 ] Offset :4608 Len :3584
[ 6.4307 ] Offset :68 Len :8124
[ 6.4309 ] Generating br-bct
[ 6.4321 ] Updating dev and MSS params in BR BCT
[ 6.4322 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.5370 ] Updating bl info
[ 6.5381 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.5404 ] Get Signed section of bct
[ 6.5415 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 6.5428 ] Signing BCT
[ 6.5436 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.5439 ] Assuming zero filled SBK key
[ 6.5473 ] Sha saved in br_bct_BR.sha
[ 6.5478 ] Warning: pub_key.key is not found
[ 6.5471 ] Updating BCT with signature
[ 6.5483 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 6.5494 ] Offset :4608 Len :3584
[ 6.5498 ] Generating SHA2 Hash
[ 6.5506 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 6.5508 ] Assuming zero filled SBK key
[ 6.5509 ] Assuming zero filled SBK key
[ 6.5544 ] Sha saved in br_bct_BR.sha
[ 6.5542 ] Updating BCT with SHA2 Hash
[ 6.5554 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 6.5565 ] Offset :4608 Len :3584
[ 6.5569 ] Offset :68 Len :8124
[ 6.5569 ]
[ 6.5571 ] Generating BCT backup image
[ 6.5571 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 6.5584 ] 32768+0 records in
[ 6.6185 ] 32768+0 records out
[ 6.6185 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0595975 s, 550 kB/s
[ 6.6185 ]
[ 6.6186 ] Concatenating BCT for chain A to bct_backup.img
[ 6.6186 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 6.6195 ] 8192+0 records in
[ 6.6316 ] 8192+0 records out
[ 6.6316 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0116993 s, 700 kB/s
[ 6.6317 ]
[ 6.6317 ] Concatenating BCT for chain B to bct_backup.img
[ 6.6317 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 6.6327 ] 8192+0 records in
[ 6.6448 ] 8192+0 records out
[ 6.6448 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0117574 s, 697 kB/s
[ 6.6448 ]
[ 6.6449 ] Generating coldboot mb1-bct
[ 6.6459 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 6.6470 ] MB1-BCT version: 0.9
[ 6.6471 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.6476 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.6480 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.6483 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.6487 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.6491 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.6494 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 6.6497 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 6.6499 ] ERROR: /misc/vmon/vdd_cpu/int/ is not supported
[ 6.6502 ] ERROR: /misc/vmon/vdd_cpu/int/ is not supported
[ 6.6504 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 6.6507 ] Added Platform Config 0 data with size :- 2416
[ 6.6511 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 6.6515 ] WARNING: unknown node 'g2'
[ 6.6515 ] WARNING: unknown node 'g9'
[ 6.6515 ] Added Platform Config 2 data with size :- 24
[ 6.6515 ]
[ 6.6515 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 6.6515 ] Added Platform Config 4 data with size :- 264
[ 6.6515 ]
[ 6.6515 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 6.6515 ] Added Platform Config 3 data with size :- 52
[ 6.6515 ]
[ 6.6515 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 6.6516 ] WARNING: unknown property 'major'
[ 6.6516 ] WARNING: unknown property 'minor'
[ 6.6516 ] Added Platform Config 5 data with size :- 500
[ 6.6516 ]
[ 6.6516 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 6.6516 ] Added Platform Config 7 data with size :- 380
[ 6.6516 ]
[ 6.6516 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 6.6516 ] Added Platform Config 9 data with size :- 100
[ 6.6516 ]
[ 6.6516 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 6.6516 ] ModuleCount 0 NumProdNames 0
[ 6.6516 ] Added Platform Config 6 data with size :- 16
[ 6.6516 ]
[ 6.6517 ] Updating mb1-bct with firmware information
[ 6.6527 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 6.6555 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 6.6580 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 6.6592 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 6.6610 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.6612 ] Assuming zero filled SBK key
[ 6.6632 ] Warning: pub_key.key is not found
[ 6.6636 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 6.6652 ] Generating recovery mb1-bct
[ 6.6662 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 6.6672 ] MB1-BCT version: 0.9
[ 6.6674 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.6680 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.6683 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.6687 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.6690 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.6694 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.6698 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 6.6701 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 6.6703 ] ERROR: /misc/vmon/vdd_cpu/int/ is not supported
[ 6.6705 ] ERROR: /misc/vmon/vdd_cpu/int/ is not supported
[ 6.6707 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 6.6710 ] Added Platform Config 0 data with size :- 2416
[ 6.6713 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 6.6716 ] WARNING: unknown node 'g2'
[ 6.6716 ] WARNING: unknown node 'g9'
[ 6.6716 ] Added Platform Config 2 data with size :- 24
[ 6.6716 ]
[ 6.6716 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 6.6716 ] Added Platform Config 4 data with size :- 264
[ 6.6716 ]
[ 6.6716 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 6.6716 ] Added Platform Config 3 data with size :- 52
[ 6.6716 ]
[ 6.6716 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 6.6716 ] WARNING: unknown property 'major'
[ 6.6716 ] WARNING: unknown property 'minor'
[ 6.6717 ] Added Platform Config 5 data with size :- 500
[ 6.6717 ]
[ 6.6717 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 6.6717 ] WARNING: unknown property 'major'
[ 6.6717 ] WARNING: unknown property 'minor'
[ 6.6717 ] Added Platform Config 7 data with size :- 380
[ 6.6717 ]
[ 6.6717 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 6.6717 ] Added Platform Config 9 data with size :- 100
[ 6.6717 ]
[ 6.6717 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 6.6717 ] ModuleCount 0 NumProdNames 0
[ 6.6717 ] Added Platform Config 6 data with size :- 16
[ 6.6717 ]
[ 6.6717 ] Updating mb1-bct with firmware information
[ 6.6727 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 6.6754 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 6.6778 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 6.6790 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 6.6809 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.6811 ] Assuming zero filled SBK key
[ 6.6831 ] Warning: pub_key.key is not found
[ 6.6837 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 6.6853 ] Generating coldboot mem-bct
[ 6.6865 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[ 6.6876 ] packing sdram params with Wb0 file tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb
[ 6.7912 ] Packing sdram param for instance[0]
[ 6.7914 ] Packing sdram param for instance[1]
[ 6.7916 ] Packing sdram param for instance[2]
[ 6.7917 ] Packing sdram param for instance[3]
[ 6.7919 ] Packing sdram param for instance[4]
[ 6.7921 ] Packing sdram param for instance[5]
[ 6.7922 ] Packing sdram param for instance[6]
[ 6.7924 ] Packing sdram param for instance[7]
[ 6.7926 ] Packing sdram param for instance[8]
[ 6.7927 ] Packing sdram param for instance[9]
[ 6.7929 ] Packing sdram param for instance[10]
[ 6.7931 ] Packing sdram param for instance[11]
[ 6.7933 ] Packing sdram param for instance[12]
[ 6.7935 ] Packing sdram param for instance[13]
[ 6.7936 ] Packing sdram param for instance[14]
[ 6.7938 ] Packing sdram param for instance[15]
[ 6.8933 ] Getting sector size from pt
[ 6.8947 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 6.8961 ] BlockSize read from layout is 0x200
[ 6.8973 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[ 6.8984 ] Binary 0 length is 58752
[ 6.8986 ] Binary 0 align length is 58880
[ 6.8997 ] Binary 1 length is 58752
[ 6.8998 ] Binary 1 align length is 58880
[ 6.9007 ] Binary 2 length is 58752
[ 6.9008 ] Binary 2 align length is 58880
[ 6.9019 ] Binary 3 length is 58752
[ 6.9020 ] Binary 3 align length is 58880
[ 6.9030 ] Buffer length is 235520
[ 6.9031 ] adding BCH for tegra234-p3767-0000-sdram-l4t_cpp_1.bct
[ 6.9034 ] new length is 243712
[ 6.9034 ]
[ 6.9048 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[ 6.9070 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 6.9082 ] Header already present for mem_coldboot_aligned.bct
[ 6.9100 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.9103 ] Assuming zero filled SBK key
[ 6.9127 ] Warning: pub_key.key is not found
[ 6.9132 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 6.9155 ] Generating recovery mem-bct
[ 6.9166 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[ 6.9176 ] packing sdram params with Wb0 file tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb
[ 7.0205 ] Packing sdram param for instance[0]
[ 7.0206 ] Packing sdram param for instance[1]
[ 7.0208 ] Packing sdram param for instance[2]
[ 7.0210 ] Packing sdram param for instance[3]
[ 7.0211 ] Packing sdram param for instance[4]
[ 7.0213 ] Packing sdram param for instance[5]
[ 7.0215 ] Packing sdram param for instance[6]
[ 7.0216 ] Packing sdram param for instance[7]
[ 7.0218 ] Packing sdram param for instance[8]
[ 7.0220 ] Packing sdram param for instance[9]
[ 7.0222 ] Packing sdram param for instance[10]
[ 7.0223 ] Packing sdram param for instance[11]
[ 7.0225 ] Packing sdram param for instance[12]
[ 7.0227 ] Packing sdram param for instance[13]
[ 7.0229 ] Packing sdram param for instance[14]
[ 7.0230 ] Packing sdram param for instance[15]
[ 7.1225 ] Reading ramcode from backup chip_info.bin file
[ 7.1226 ] RAMCODE Read from Device: 0
[ 7.1226 ] Using ramcode 0
[ 7.1226 ] Disabled BPMP dtb trim, using default dtb
[ 7.1226 ]
[ 7.1240 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 7.1264 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --appendsigheader mem_rcm_aligned.bct zerosbk
[ 7.1276 ] adding BCH for mem_rcm_aligned.bct
[ 7.1312 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.1314 ] Assuming zero filled SBK key
[ 7.1335 ] Warning: pub_key.key is not found
[ 7.1341 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 7.1358 ] Copying signatures
[ 7.1369 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 7.5583 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 7.5589 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 7.5589 ] Boot Rom communication
[ 7.5602 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 7.5611 ] BR_CID: 0x80012344705DD1903C0000000BFF0080
[ 7.5868 ] Sending bct_br
[ 7.6300 ] Sending mb1
[ 7.7207 ] Sending psc_bl1
[ 7.7294 ] Sending bct_mb1
[ 7.7354 ] Boot Rom communication completed
[ 7.7355 ] Generating blob for T23x
[ 7.7465 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_with_dtb_aligned.bin
[ 7.7502 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[ 7.7513 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[ 7.8571 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.8573 ] Assuming zero filled SBK key
[ 7.8655 ] Warning: pub_key.key is not found
[ 7.8664 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[ 7.8753 ] Get magic id
[ 7.8765 ] tegraparser_v2 --get_magic psc_fw
[ 7.8775 ] PFWP
[ 7.8775 ]
[ 7.8776 ] partition type psc_fw, magic id = PFWP
[ 7.8792 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[ 7.8815 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[ 7.8826 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[ 7.8914 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.8916 ] Assuming zero filled SBK key
[ 7.8941 ] Warning: pub_key.key is not found
[ 7.8945 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 7.8969 ] Get magic id
[ 7.8978 ] tegraparser_v2 --get_magic mts_mce
[ 7.8989 ] MTSM
[ 7.8989 ]
[ 7.8989 ] partition type mts_mce, magic id = MTSM
[ 7.9004 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[ 7.9029 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[ 7.9041 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[ 7.9090 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.9093 ] Assuming zero filled SBK key
[ 7.9116 ] Warning: pub_key.key is not found
[ 7.9121 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[ 7.9144 ] Get magic id
[ 7.9155 ] tegraparser_v2 --get_magic mb2_applet
[ 7.9167 ] MB2A
[ 7.9167 ]
[ 7.9168 ] partition type mb2_applet, magic id = MB2A
[ 7.9184 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[ 7.9209 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader blob_applet_t234_aligned.bin zerosbk
[ 7.9220 ] adding BCH for blob_applet_t234_aligned.bin
[ 7.9352 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.9354 ] Assuming zero filled SBK key
[ 7.9381 ] Warning: pub_key.key is not found
[ 7.9386 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[ 7.9420 ] Generating recovery mb2-bct
[ 7.9421 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 7.9432 ] WARNING: unknown property 'tfc_version'
[ 7.9446 ] WARNING: unknown property 'addr_header_version'
[ 7.9561 ] Updating mb2-bct with storage information
[ 7.9571 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 7.9588 ] Concatenating mb2-bct to mb2 binary
[ 7.9588 ] mb2_bin_file = mb2_t234.bin
[ 7.9588 ] mb2_bct_file = mb2_bct_MB2.bct
[ 7.9596 ] Get magic id
[ 7.9608 ] tegraparser_v2 --get_magic mb2_bootloader
[ 7.9620 ] MB2B
[ 7.9620 ]
[ 7.9620 ] partition type mb2_bootloader, magic id = MB2B
[ 7.9637 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 7.9659 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[ 7.9670 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 7.9841 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.9843 ] Assuming zero filled SBK key
[ 7.9874 ] Warning: pub_key.key is not found
[ 7.9878 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[ 7.9904 ] Get magic id
[ 7.9913 ] tegraparser_v2 --get_magic xusb_fw
[ 7.9924 ] XUSB
[ 7.9924 ]
[ 7.9924 ] partition type xusb_fw, magic id = XUSB
[ 7.9939 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[ 7.9963 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[ 7.9976 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[ 8.0068 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.0071 ] Assuming zero filled SBK key
[ 8.0097 ] Warning: pub_key.key is not found
[ 8.0103 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 8.0123 ] Kernel DTB used: kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
[ 8.0124 ] Concatenating kernel-dtb to dce-fw binary
[ 8.0124 ] dce_bin = display-t234-dce.bin
[ 8.0124 ] kernel_dtb = kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
[ 8.0124 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0.bin
[ 8.0215 ] Get magic id
[ 8.0228 ] tegraparser_v2 --get_magic dce_fw
[ 8.0241 ] DCEF
[ 8.0241 ]
[ 8.0241 ] partition type dce_fw, magic id = DCEF
[ 8.0326 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin
[ 8.0352 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --appendsigheader blob_display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin zerosbk
[ 8.0365 ] adding BCH for blob_display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin
[ 8.3494 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.3497 ] Assuming zero filled SBK key
[ 8.3712 ] Warning: pub_key.key is not found
[ 8.3721 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned_sigheader.bin.hash zerosbk
[ 8.3928 ] Get magic id
[ 8.3943 ] tegraparser_v2 --get_magic nvdec
[ 8.3957 ] NDEC
[ 8.3958 ]
[ 8.3958 ] partition type nvdec, magic id = NDEC
[ 8.3980 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[ 8.4005 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[ 8.4018 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[ 8.4080 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.4083 ] Assuming zero filled SBK key
[ 8.4110 ] Warning: pub_key.key is not found
[ 8.4116 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[ 8.4140 ] Get magic id
[ 8.4151 ] tegraparser_v2 --get_magic bpmp_fw
[ 8.4162 ] BPMF
[ 8.4163 ]
[ 8.4163 ] partition type bpmp_fw, magic id = BPMF
[ 8.4189 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[ 8.4214 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --appendsigheader blob_bpmp_t234-TE990M-A1_prod_aligned.bin zerosbk
[ 8.4226 ] Header already present for blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[ 8.4425 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.4428 ] Assuming zero filled SBK key
[ 8.4468 ] Warning: pub_key.key is not found
[ 8.4473 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.hash zerosbk
[ 8.4509 ] Using bpmp-dtb concatenated with odmdata in blob
[ 8.4510 ] Get magic id
[ 8.4520 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[ 8.4534 ] BPMD
[ 8.4534 ]
[ 8.4535 ] partition type bpmp_fw_dtb, magic id = BPMD
[ 8.4551 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 8.4576 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --appendsigheader blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb zerosbk
[ 8.4588 ] adding BCH for blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 8.4654 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.4656 ] Assuming zero filled SBK key
[ 8.4680 ] Warning: pub_key.key is not found
[ 8.4686 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[ 8.4707 ] Get magic id
[ 8.4718 ] tegraparser_v2 --get_magic sce_fw
[ 8.4729 ] SCEF
[ 8.4729 ]
[ 8.4730 ] partition type sce_fw, magic id = SCEF
[ 8.4746 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-sce_aligned.img
[ 8.4770 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --appendsigheader blob_camera-rtcpu-sce_aligned.img zerosbk
[ 8.4782 ] adding BCH for blob_camera-rtcpu-sce_aligned.img
[ 8.4856 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-sce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.4858 ] Assuming zero filled SBK key
[ 8.4882 ] Warning: pub_key.key is not found
[ 8.4888 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-sce_aligned_sigheader.img.encrypt blob_camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[ 8.4912 ] Get magic id
[ 8.4924 ] tegraparser_v2 --get_magic rce_fw
[ 8.4937 ] RCEF
[ 8.4937 ]
[ 8.4937 ] partition type rce_fw, magic id = RCEF
[ 8.4957 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[ 8.4982 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[ 8.4994 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[ 8.5212 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.5215 ] Assuming zero filled SBK key
[ 8.5245 ] Warning: pub_key.key is not found
[ 8.5250 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[ 8.5280 ] Get magic id
[ 8.5290 ] tegraparser_v2 --get_magic ape_fw
[ 8.5303 ] APEF
[ 8.5303 ]
[ 8.5303 ] partition type ape_fw, magic id = APEF
[ 8.5321 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[ 8.5346 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[ 8.5358 ] adding BCH for blob_adsp-fw_aligned.bin
[ 8.5526 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.5528 ] Assuming zero filled SBK key
[ 8.5556 ] Warning: pub_key.key is not found
[ 8.5561 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[ 8.5584 ] Get magic id
[ 8.5594 ] tegraparser_v2 --get_magic spe_fw
[ 8.5605 ] SPEF
[ 8.5606 ]
[ 8.5606 ] partition type spe_fw, magic id = SPEF
[ 8.5622 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[ 8.5650 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --appendsigheader blob_spe_t234_aligned.bin zerosbk
[ 8.5663 ] adding BCH for blob_spe_t234_aligned.bin
[ 8.5774 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.5776 ] Assuming zero filled SBK key
[ 8.5801 ] Warning: pub_key.key is not found
[ 8.5806 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[ 8.5828 ] Get magic id
[ 8.5838 ] tegraparser_v2 --get_magic tos
[ 8.5850 ] TOSB
[ 8.5850 ]
[ 8.5850 ] partition type tos, magic id = TOSB
[ 8.5874 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[ 8.5897 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[ 8.5909 ] adding BCH for blob_tos-optee_t234_aligned.img
[ 8.6291 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.6294 ] Assuming zero filled SBK key
[ 8.6333 ] Warning: pub_key.key is not found
[ 8.6340 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[ 8.6380 ] Get magic id
[ 8.6392 ] tegraparser_v2 --get_magic eks
[ 8.6404 ] EKSB
[ 8.6405 ]
[ 8.6405 ] partition type eks, magic id = EKSB
[ 8.6418 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[ 8.6444 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --appendsigheader blob_eks_t234_aligned.img zerosbk
[ 8.6456 ] adding BCH for blob_eks_t234_aligned.img
[ 8.6471 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.6474 ] Assuming zero filled SBK key
[ 8.6496 ] Warning: pub_key.key is not found
[ 8.6502 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[ 8.6536 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 8.6548 ] The number of images in blob is 16
[ 8.6551 ] blobsize is 17987312
[ 8.6552 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3171168
[ 8.6640 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 8.6648 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 8.6652 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 8.6656 ] Not supported type: mb2_applet
[ 8.6658 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 437760
[ 8.6662 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[ 8.6666 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_sigheader.bin.encrypt of size 9438928
[ 8.6727 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 8.6750 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1047616
[ 8.6758 ] Added binary blob_tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
[ 8.6762 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 8.6766 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 8.6769 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400944
[ 8.6772 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 8.6775 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[ 8.6779 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 8.6871 ] Sending membct and RCM blob
[ 8.6885 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 8.6897 ] BL: version 0.28.0.0-t234-54845784-ec016368 last_boot_error: 0
[ 8.7184 ] Sending bct_mem
[ 8.7622 ] Sending blob
[ 9.9974 ] completed
[ 11.0031 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1018.2573 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 2035.0679 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
