Jestson Xavier NX CSI PWDN/MCLK
Hello Team
I am usnig the following MIPI camera VC MIPI IMX392 C
link to the web site
VC MIPI Camera Module Hardware Operating Manual (vision-components.com)](VC MIPI Camera Module Hardware Operating Manual)
The camera does not include the PWDN/MCLK signals.
The camera has Trigger input and flash output instead.
My questions are:
  1. What is the functionality of PWDN?
  2. What is the functionality of MCLK?
  3. If the PWDN/MCLK are not connected will there be any dagradation?
  4. How should i connect Trigger and Flash output signals of the camera?
Regards,
Roey
How should i handle this pins?
Usually the PWDN is the power enable PIN for sensor.
And MCLK is the input clock for the sensor without them the sensor unable working. And current Jetson don’t support LED flash light.
Hi
You didnt answer my questions.
Can the Jestson NX operate the CSI interface without the MCLK?
So i can disconnect MCLK from Jetson and it will operate correctly?
The camera vendor specifies that the camera can operate with NVIDIA Jestson NX
You can see it in the link i attached before.
Regards,
Roey
MCLK is output for sensor doesn’t matter with Jetson NX.
Thanks for the answer
I just wondered if the jetson needs to be synchronised to the CSI output with respect to mclk?
נשלח מה-iPhone שלי
‫ב-12 בדצמ׳ 2022, בשעה 9:58, ‏‏ShaneCCC via NVIDIA Developer Forums ‏notifications@nvidia.discoursemail.com כתב/ה:‬
CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.
| ShaneCCC Moderator
December 12 |
tal.roey:
Visit Topic or reply to this email to respond.
To unsubscribe from these emails, click here.
The information in this electronic message and any attachments (the “Message”) is intended for one or more specific individuals or entities, and may contain proprietary, business sensitive, confidential or otherwise protected by law information. Unauthorized interception of this e-mail may constitute a violation of law. If you are not the intended recipient, please notify the sender immediately, delete this Message, and do not disclose, distribute, or copy it to any third party or otherwise use this Message. Electronic messages are not secure or error free and can contain viruses or may be delayed, and the sender is not liable for any of these occurrences. This Message is not intended to create, and receipt of it does not constitute, a contractual or other binding relationship.
