Jet pack 4.3 cannot install opencv
My tx2 installation appears like the following during installation of opencv, or try with sudo apt-get update:
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic/main/binary-amd64/Packages 404 Not Found [IP: 91.189.88.150 80]
E: Failed to fetch https://repo.download.nvidia.cn/jetson/t186/dists/r32/main/binary-arm64/Packages.gz File has unexpected size (8084 != 7930). Mirror sync in progress? [IP: 120.226.193.66 443]
Hashes of expected file:
  • Filesize:7930 [weak]
  • SHA256:a80383566cab2ea7baa68c7c17ac6f581b7ec47d376d832c1824d2fd1ab8916e
  • SHA1:268b9c78b441a358f804dab1b1c67c7c91ffbad7 [weak]
  • MD5Sum:6d1e8cb93e0f23410eecfd8007d2e4df [weak]
    Release file created at: Tue, 17 Dec 2019 23:52:06 +0000
    E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/main/binary-amd64/Packages 404 Not Found [IP: 91.189.88.150 80]
    E: Some index files failed to download. They have been ignored, or old ones used instead.
when I install numpy 1.16.1 or 1.18.1,
it also has a problem , reminding me a lot of libraries are lacked in usr/bin
like:
blis_info:
customize UnixCCompiler
libraries blis not found in [’/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
Do you see this error on your host?
