I started working on a jetbot project last week, implementing the Jetbot_ros solution ( GitHub - dusty-nv/jetbot_ros: ROS nodes and Gazebo model for NVIDIA JetBot with Jetson Nano) last week. All instructions followed on GitHub - dusty-nv/jetbot_ros: ROS nodes and Gazebo model for NVIDIA JetBot with Jetson Nano with no errors.
I’m receiving an i2c I/O Error 121. when running the ros node: rosrun jetbot_ros jetbot_motors.py. I tried many things to resolve this but have not been able worked. The sudo i2cdetect -y -r 1 command showed the OLED display at 0X30 but nothing for the the Adafruit driver board.
I tried just connecting the board to the nano pins directly, without the OLED, no luck.
I changed the Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py line 227 change:
def init (self, addr = 0x60, freq = 1600, i2c=None, i2c_bus=None):
to:
def init (self, addr = 0x60, freq = 1600, i2c=None, i2c_bus = 1): no luck.
I check the wiring based on , no luck…
Checked all solder points.
The power light is on on the Adafruit Board
JetPack 4.5.1
Ubuntu 18.04 LTS
ROS Melodic
Using GPIO Nano Pins 1,3,5,6
ros@jetson:~/workspace/catkin_ws/src/jetbot_ros/scripts$ sudo i2cdetect -y -r 1
[sudo] password for ros: shows the OLED but not the DC Motor Driver
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – 3c – – –
40: – – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
RUN node:
CODE for jetbot_motors.py:
#!/usr/bin/env python
import rospy
import time
from Adafruit_MotorHAT import Adafruit_MotorHAT
from std_msgs.msg import String
sets motor speed between [-1.0, 1.0]
def set_speed(motor_ID, value):
max_pwm = 115.0
speed = int(min(max(abs(value * max_pwm), 0), max_pwm))
if motor_ID == 1:
motor = motor_left
elif motor_ID == 2:
motor = motor_right
else:
rospy.logerror(‘set_speed(%d, %f) → invalid motor_ID=%d’, motor_ID, value, motor_ID)
return
motor.setSpeed(speed)
if value > 0:
motor.run(Adafruit_MotorHAT.FORWARD)
else:
motor.run(Adafruit_MotorHAT.BACKWARD)
stops all motors
def all_stop():
motor_left.setSpeed(0)
motor_right.setSpeed(0)
motor_left.run(Adafruit_MotorHAT.RELEASE)
motor_right.run(Adafruit_MotorHAT.RELEASE)
directional commands (degree, speed)
def on_cmd_dir(msg):
rospy.loginfo(rospy.get_caller_id() + ’ cmd_dir=%s’, msg.data)
raw L/R motor commands (speed, speed)
def on_cmd_raw(msg):
rospy.loginfo(rospy.get_caller_id() + ’ cmd_raw=%s’, msg.data)
simple string commands (left/right/forward/backward/stop)
def on_cmd_str(msg):
rospy.loginfo(rospy.get_caller_id() + ’ cmd_str=%s’, msg.data)
if msg.data.lower() == “left”:
set_speed(motor_left_ID, -1.0)
set_speed(motor_right_ID, 1.0)
elif msg.data.lower() == “right”:
set_speed(motor_left_ID, 1.0)
set_speed(motor_right_ID, -1.0)
elif msg.data.lower() == “forward”:
elif msg.data.lower() == “backward”:
elif msg.data.lower() == “stop”:
all_stop()
else:
rospy.logerror(rospy.get_caller_id() + ’ invalid cmd_str=%s’, msg.data)
initialization
if name == ’ main ':
setup motor controller
motor_driver = Adafruit_MotorHAT(i2c_bus=1)
motor_left_ID = 1
motor_right_ID = 2
motor_left = motor_driver.getMotor(motor_left_ID)
motor_right = motor_driver.getMotor(motor_right_ID)
stop the motors as precaution
all_stop()
setup ros node
rospy.init_node(‘jetbot_motors’)
rospy.Subscriber(‘~cmd_dir’, String, on_cmd_dir)
rospy.Subscriber(‘~cmd_raw’, String, on_cmd_raw)
rospy.Subscriber(‘~cmd_str’, String, on_cmd_str)
start running
rospy.spin()
stop motors before exiting
all_stop()
ros@jetson:~/workspace/catkin_ws/src/jetbot_ros/scripts$ rosrun jetbot_ros jetbot_motors.py
File “/home/ros/workspace/catkin_ws/src/jetbot_ros/scripts/jetbot_motors.py”, line 75, in
File “/home/ros/.local/lib/python2.7/site-packages/Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py”, line 231, in init
self._pwm = PWM(addr, debug=False, i2c=i2c, i2c_bus=i2c_bus)
File “/home/ros/.local/lib/python2.7/site-packages/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py”, line 59, in init
self.setAllPWM(0, 0)
File “/home/ros/.local/lib/python2.7/site-packages/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py”, line 95, in setAllPWM
self.i2c.write8(self.__ALL_LED_ON_L, on & 0xFF)
File “/home/ros/.local/lib/python2.7/site-packages/Adafruit_GPIO/I2C.py”, line 114, in write8
self._bus.write_byte_data(self._address, register, value)
File “/home/ros/.local/lib/python2.7/site-packages/Adafruit_PureIO/smbus.py”, line 268, in write_byte_data
self._device.write(data)
IOError: [Errno 121] Remote I/O error
Any thoughts?
