Jetbot (Jetson nano 2GB) Remote I/O error
I am trying to run the basic_motion.py file (from the examples jetbot folder) and i am getting this error “Remote I/O error”.
I saw on YouTube (DIY JETBOT with DC Motor Driver ( H-Bridge ) Jetson Nano | AI Robot - YouTube) that i need to edit the file “/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py” from addr=0x60 to 0x40 i do not have a clue if its right or know-anywhere i can not access to this file (i am getting empty file on “sudo gedit /usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py”
Could someone tell me please what is the problem here and how can i fix it? ( i used the jetson nano2GB jetbot image from Jetbot website)
OSErrorTraceback (most recent call last)
<ipython-input-2-b418ad9f6ab3> in <module>
----> 1 robot = Robot()
/usr/local/lib/python3.6/dist-packages/jetbot-0.4.3-py3.6.egg/jetbot/robot.py in __init__(self, *args, **kwargs)
     20     def __init__(self, *args, **kwargs):
     21         super(Robot, self).__init__(*args, **kwargs)
---> 22         self.motor_driver = Adafruit_MotorHAT(i2c_bus=self.i2c_bus)
     23         self.left_motor = Motor(self.motor_driver, channel=self.left_motor_channel, alpha=self.left_motor_alpha)
     24         self.right_motor = Motor(self.motor_driver, channel=self.right_motor_channel, alpha=self.right_motor_alpha)
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py in __init__(self, addr, freq, i2c, i2c_bus)
    229         self.motors = [ Adafruit_DCMotor(self, m) for m in range(4) ]
    230         self.steppers = [ Adafruit_StepperMotor(self, 1), Adafruit_StepperMotor(self, 2) ]
--> 231         self._pwm = PWM(addr, debug=False, i2c=i2c, i2c_bus=i2c_bus)
    232         self._pwm.setPWMFreq(self._frequency)
    233
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py in __init__(self, address, debug, i2c, i2c_bus)
     57         self.i2c = get_i2c_device(address, i2c, i2c_bus)
     58         logger.debug("Reseting PCA9685 MODE1 (without SLEEP) and MODE2")
---> 59         self.setAllPWM(0, 0)
     60         self.i2c.write8(self.__MODE2, self.__OUTDRV)
     61         self.i2c.write8(self.__MODE1, self.__ALLCALL)
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py in setAllPWM(self, on, off)
     93     def setAllPWM(self, on, off):
     94         "Sets a all PWM channels"
---> 95         self.i2c.write8(self.__ALL_LED_ON_L, on & 0xFF)
     96         self.i2c.write8(self.__ALL_LED_ON_H, on >> 8)
     97         self.i2c.write8(self.__ALL_LED_OFF_L, off & 0xFF)
/usr/local/lib/python3.6/dist-packages/Adafruit_GPIO-1.0.4-py3.6.egg/Adafruit_GPIO/I2C.py in write8(self, register, value)
    114         """Write an 8-bit value to the specified register."""
    115         value = value & 0xFF
--> 116         self._bus.write_byte_data(self._address, register, value)
    117         self._logger.debug("Wrote 0x%02X to register 0x%02X",
    118                      value, register)
/usr/local/lib/python3.6/dist-packages/Adafruit_PureIO-1.1.8-py3.6.egg/Adafruit_PureIO/smbus.py in write_byte_data(self, addr, cmd, val)
    320         # Send the data to the device.
    321         self._select_device(addr)
--> 322         self._device.write(data)
    323
    324     def write_word_data(self, addr, cmd, val):
OSError: [Errno 121] Remote I/O error
Sorry for the late response, is this still an issue to support?
Correct. Thanks
