Jetbot on battery: Camera delayed with object following example
When running the Jetbot object following example in battery mode (3A) the camera stream is delayed. The delay starts with executing object detection. Without it the camera works as expected. It seems to me that the power is too little in battery mode because it works on power supply. But a Jetbot on power supply with a cable doesn’t make sense. Any ideas how I can make it working in battery mode? The car is just turning left because object detection doesn’t work properly. :-D
Thanks a lot in advance!
Best,
Sören
Hi sbrockmann,
Please refer to below thread is can help: External battery power supply - #2 by dusty_nv
