Hello, I get an error early on in running this container.
Does anyone have a suggestion to get this going?
Exception in thread Thread-4:
File “/usr/lib/python3.6/threading.py”, line 916, in _bootstrap_inner
self.run()
File “/usr/lib/python3.6/threading.py”, line 864, in run
self._target(*self._args, **self._kwargs)
File “/usr/local/lib/python3.6/dist-packages/jetbot-0.4.3-py3.6.egg/jetbot/camera/opencv_gst_camera.py”, line 45, in _capture_frames
self.value = image
File “/usr/local/lib/python3.6/dist-packages/traitlets/traitlets.py”, line 588, in set
self.set(obj, value)
File “/usr/local/lib/python3.6/dist-packages/traitlets/traitlets.py”, line 577, in set
obj._notify_trait(self.name, old_value, new_value)
File “/usr/local/lib/python3.6/dist-packages/traitlets/traitlets.py”, line 1210, in _notify_trait
type=‘change’,
File “/usr/local/lib/python3.6/dist-packages/traitlets/traitlets.py”, line 1215, in notify_change
return self._notify_observers(change)
File “/usr/local/lib/python3.6/dist-packages/traitlets/traitlets.py”, line 1252, in _notify_observers
c(event)
File “/usr/local/lib/python3.6/dist-packages/traitlets/traitlets.py”, line 361, in _update
self._transform(change.new))
File “”, line 19, in display_xy
image = cv2.circle(image, (widget_width / 2, widget_height), 8, (0, 0,255), 3)
TypeError: integer argument expected, got float
TypeErrorTraceback (most recent call last)
in
24 time.sleep(1)
25 traitlets.dlink((camera, ‘value’), (image_widget, ‘value’), transform=bgr8_to_jpeg)
—> 26 traitlets.dlink((camera, ‘value’), (target_widget, ‘value’), transform=display_xy)
27
28 display(widgets.HBox([image_widget, target_widget]), x_slider, y_slider)
/usr/local/lib/python3.6/dist-packages/traitlets/traitlets.py in init(self, source, target, transform)
337 _validate_link(source, target)
338 self.source, self.target = source, target
→ 339 self.link()
340
341 def link(self):
/usr/local/lib/python3.6/dist-packages/traitlets/traitlets.py in link(self)
342 try:
343 setattr(self.target[0], self.target[1],
→ 344 self._transform(getattr(self.source[0], self.source[1])))
345 finally:
346 self.source[0].observe(self._update, names=self.source[1])
in display_xy(camera_image)
17 y = int(y * widget_height / 2 + widget_height / 2)
18 image = cv2.circle(image, (x, y), 8, (0, 255, 0), 3)
—> 19 image = cv2.circle(image, (widget_width / 2, widget_height), 8, (0, 0,255), 3)
20 image = cv2.line(image, (x,y), (widget_width / 2, widget_height), (255,0,0), 3)
21 jpeg_image = bgr8_to_jpeg(image)
TypeError: integer argument expected, got floatException in thread Thread-4:
self.run()
self.value = image
type=‘change’,
c(event)
in
24 time.sleep(1)
27
→ 339 self.link()
340
341 def link(self):
342 try:
345 finally:
