I have a jeton orin NX that can run the sudo /opt/nvidia/jetson-io/ Jetson-io.py command and configure GPIO after brushing the machine. However, in the later use process, after I run this command, the configuration interface will blink back. I can only solve this problem by swiping the computer before, so I want to know the cause of the problem and the solution.
麻煩先附上基本資訊
DevKit還是custom board 還有L4T/JetPack版本
這句的意思是重燒?
知道问题所在了,通过sudo /opt/nvidia/jetson-io/config-by-pin.py -l 发现是
删除后解决了闪退的问题。
然后进行删除的时候不小心都删掉了,查询了部分方法后,没有办法直接恢复,只能选择重新刷机了
你的板子還能正常開機使用的話 從BSP裡直接把那些檔案用ssh之類的方法複製回去應該就可以了
不需要重刷才對
