Uploading: KakaoTalk_20220822_161001592.jpg…
how can i solve?
default ip is not available. please make sure the defualt ip is shown in ip adr, or use a customer ip instead.
Hi ykcar119,
Are you connect type-C flash cable on your Xavier board to host?
If yes, you can see the “192.168.55.1” IP via ifconfig.
You also can select etherent and enter the IP address instead of IPv4 to install SDK components.
