Jetpack 2.0 Installation on Jetson TX1
I am trying to install Jetpack 2.0 on Jetson TX1.I followed all the steps.While installing,it asks for a “Enter” input from the User.After pressing Enter key,there is no visible action being performed.I closed the installation process and tried to run OpenGL samples.
I tried all the simulation based samples in Simulation Folder on Jetson.But only smoke,particle and nbody samples are running.
OceanFFT and FluidsGL samples do not run.
So is this because of the incomplete installation process?What do I do to rectify it.
This is how XTerm terminal shows when it stops the further installation.
Hi nirajsp47,
Would you mind to move on JetPack2.3?
[url]https://developer.nvidia.com/embedded/jetpack-notes[/url]
