Jetpack 2.1 install fails with 'error 29'.
I am not able to install anything using Jetpack 2.1 (even the locally installed common components like the debugger)-- it always fails immediately with ‘error 29’. Any clue what that means?
I have had absolutely no problems installing Jetpack 2.0 or any previous release for the TX1 or TK1 with my same setup (Ubuntu 14.4 in VMWare Workstation 10 on Windows 8 x64). Have the requirements changed?
thanks,
tonyvr
Hi tonyvr,
There is a know issue: JetPack doesn’t support spaces in installation path. Please use a path without spaces if current one has.
Yup, I forgot to use an underscore rather than a space. It’s working now. Thanks!
tonyvr
