I’m running Ubuntu 14.04 64-bit in my host machine and I’m trying to run JetPack 2.1. I’m executing the .run file with my non-root user. Flashing TK1 finishes ok and I see this:
1
Finished Flashing OS
Determining the IP address of target...
192.168.1.4
Waiting 30 seconds to make sure target is fully up
# Host 192.168.1.4 found: line 1 type RSA
# Host 192.168.1.4 found: line 2 type ECDSA
/home/martin/.ssh/known_hosts updated.
Original contents retained as /home/martin/.ssh/known_hosts.old
# 192.168.1.4 SSH-2.0-OpenSSH_6.6.1p1 Ubuntu-2ubuntu2
/home/martin
Identity added: /home/martin/.ssh/id_rsa (/home/martin/.ssh/id_rsa)
scp -o PubkeyAuthentication=no -o ConnectTimeout=30 -o StrictHostKeyChecking=no /home/martin/.ssh/id_rsa.pub ubuntu@192.168.1.4:/home/ubuntu/tmp.pub
8.1.4
id_rsa.pub 100% 395 0.4KB/s 00:00
ubuntu@tegra-ubuntu:~$ b /home/ubuntu/.ssh/authorized_keys
ubuntu@tegra-ubuntu:~$ exit
logout
Connection to 192.168.1.4 closed
Then, the installation gets stuck forever. I have tried deleting the .ssh folder on the host without any luck.
Also, if I set “no action” for flashing (so I start the process pushing and installing CUDA), it also gets stuck while installing files:
ubuntu@192.168.1.4's password:
Copying cuda-repo-l4t-r21.3-6-5-local_6.5-50_armhf.deb file to target...
568,399,644 100% 256.53MB/s 0:00:02 (xfr#1, to-chk=0/1)
sent 95,496 bytes received 166,944 bytes 13,458.46 bytes/sec
total size is 568,399,644 speedup is 2,165.83
And that is the last thing I see.
If it is of any help, when I access the TK1 (via ssh or directly), the default user:ubuntu, pass:ubuntu user account doesn’t have root privileges. When I try to sudo anything I get:
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
And I can’t find the root user password (to login as root).
Any ideas?
