Jetpack 2.3 installation. 64 bit on the SD card lead to a mistake
Good afternoon. Despite numerous attempts and reading this forum I do not manage to receive completely efficient system on the SD card. in attempt to cause some programs in particular of ubuntu software there is an error of permission denied and the program stops work. I can establish different the program via the terminal and apt-get install, but I cannot use a graphic application :( who has thoughts in what there can be a problem and how to solve it?
ubuntu@tegra-ubuntu:/usr/bin$ ./software-properties-gtk
/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py:40: PyGIWarning: Gdk was imported without specifying a version first. Use gi.require_version('Gdk', '3.0') before import to ensure that the right version gets loaded.
  from gi.repository import GObject, Gdk, Gtk, Gio, GLib
/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py:40: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 175, in activate_name_owner
    return self.get_name_owner(bus_name)
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 361, in get_name_owner
    's', (bus_name,), **keywords)
  File "/usr/lib/python3/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name 'com.ubuntu.SoftwareProperties': no such name
During handling of the above exception, another exception occurred:
  File "./software-properties-gtk", line 101, in <module>
    app = SoftwarePropertiesGtk(datadir=options.data_dir, options=options, file=file)
  File "/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py", line 141, in __init__
    proxy = bus.get_object("com.ubuntu.SoftwareProperties", "/")
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 241, in get_object
    follow_name_owner_changes=follow_name_owner_changes)
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 248, in __init__
    self._named_service = conn.activate_name_owner(bus_name)
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 180, in activate_name_owner
    self.start_service_by_name(bus_name)
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 278, in start_service_by_name
    'su', (bus_name, flags)))
    message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program com.ubuntu.SoftwareProperties: Permission denied
I don’t know what the problem is, but first see if base install seems correct:
sha1sum -c /etc/nv_tegra_release
Second, how was the system flashed? With JetPack, or driver package plus sample rootfs on command line? What is the current L4T vesion (“head -n 1 /etc/nv_tegra_release”)? Was the flash software run from a native Linux file system type (“df -T /wherever/your/install/is/Linux_for_Tegra”)?
Have your tried manually copy rootfs to SD card in stead of using Jetpack?
Manually copy to SD card (“sudo cp -a rootfs/* /mnt && sync”) worked for me:
https://devtalk.nvidia.com/default/topic/967023/l4t24-2-on-sd-cards-crashes-/
I tried to install system and from jetpack 2.3 (Tegra210_Linux_R24.2.1_aarch64.tbz2, Tegra_Linux_Sample-Root-Filesystem_R24.2.1_aarch64), also tried from http://developer.nvidia.com/embedded/dlc/l4t-sample-root-filesystem-24-2, http://developer.nvidia.com/embedded/dlc/l4t-jetson-tx1-driver-package-24-2. The result is identical. Here check according to the command submitted by you.
ubuntu@tegra-ubuntu:/usr/bin$ sha1sum -c /etc/nv_tegra_release
/usr/lib/aarch64-linux-gnu/tegra/libnvosd.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_image.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvomx.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmedia.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_utils.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libglx.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libscf.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvexif.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvfnetstorehdfx.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmm_parser.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvrm.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmm_contentpipe.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvos.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvtnr.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvfnet.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvavp.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvfnetstoredefog.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvodm_imager.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvtvmr.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvdc.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libtegrav4l2.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmm.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvapputil.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcameratools.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcam_imageencoder.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnveglstream_camconsumer.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmm_utils.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvomxilclient.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libargus.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvwinsys.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libargus_socketclient.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnveglstreamproducer.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvll.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libargus_socketserver.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvrm_graphics.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcolorutil.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvddk_2d_v2.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvtestresults.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcamerautils.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvcamlog.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvparser.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvddk_vic.so: OK
/usr/lib/aarch64-linux-gnu/tegra/libnvmmlite.so: OK
/usr/lib/aarch64-linux-gnu/libv4l/plugins/libv4l2_nvvidconv.so: OK
/usr/lib/aarch64-linux-gnu/libv4l/plugins/libv4l2_nvvideocodec.so: OK
/usr/lib/xorg/modules/drivers/nvidia_drv.so: OK
/usr/lib/xorg/modules/extensions/libglx.so: OK
ubuntu@tegra-ubuntu:/usr/bin$ head -n 1 /etc/nv_tegra_release
# R24 (release), REVISION: 2.1, GCID: 7791156, BOARD: t210ref, EABI: aarch64, DATE: Thu Sep 29 00:59:21 UTC 2016
If I everything correctly understood that yes all was put and with Ubuntu Linux 14.04.01, on SD from ext4. and directly with jetson TX1 (when it works for EMMC).
[/code]
[/quote]
[/quote]
At you it is told
“I found a way to work around the issue by using another Ubuntu laptop to copy L4T 24.2 rootfs to SD card:”
But I didn’t understand as it works and didn’t use.
If not difficult give an example from unpacking of files of drivers and a sample of file system, to the end result (working system on SD card).
It’s in “l4t_getting_started.html”
To set up the rootfs
1. Download the following file to your home directory:
Tegra-Linux-Sample-Root-Filesystem_<release_type>.tbz2
This file contains the NVIDIA-provided sample root file system.
2. Extract the compressed file as follows:
•Navigate to the rootfs directory of the extracted NVIDIA driver package with this command:
$ cd <your_L4T_root>/Linux_for_Tegra/rootfs
Where <your_L4T_root> is your L4T root directory, which is assumed to be your home directory (~).
For more information, see Extracting Tegra Linux Driver Package in this section.
•Extract the sample file system to the rootfs directory with this command:
$ sudo tar -jxpf ../../Tegra-Linux-Sample-Root-Filesystem_<release_type>.tbz2
3. Run the apply_binaries.sh script to copy the NVIDIA user space libraries into the target file system:
$ cd ..
$ sudo ./apply_binaries.sh
Step 2: Copy the rootfs to the Device
Use these procedures to copy the file system to the Tegra device.
1. Pick a device to place your rootfs.
•If you are using the internal EMMC, skip ahead to Flashing the Bootloader and Kernel.
2. If you prefer to use an external storage device for the root filesystem, use the following procedure.
To copy the file system to an external storage device
1. Plug your rootfs device into the host system.
2. If your device is not formatted as Ext4, enter the following command to format it with an Ext4 file system:
$ sudo mkfs.ext4 /dev/sd<port><device number>
Where:
•<port> is the port to which your device is mounted.
•<device_number> is the device number of the device attached to the port. You can use the dmesg command to determine the port.
3. If needed, mount your device with the following command:
$ sudo mount /dev/sdX1 <mntpoint>
Where <mntpoint> is the mount point on the host system for your rootfs device.
4. Copy the file system. If LDK_ROOTFS_DIR is set, execute these commands:
$ cd ${LDK_ROOTFS_DIR}
$ sudo cp -a * <mntpoint> && sync
5. If it is not set, copy the rootfs directory that is included in the release by executing the following commands:
Assuming you already have one partition on SD card, if you put SD card in a ubuntu laptop with SD card slot, the the first partition of SD card should show as “/dev/mmcblk0p1”, if you use SD card to USB adapter, the first partition of SD card could show as “/dev/sdb1”.
In the first case, you would use the following from ubuntu laptop:
$ sudo mkfs.ext4 /dev/mmcblk0p1
$ sudo mount /dev/mmcblk0p1 /mnt
$ sudo cp -a * /mnt && sync
Good afternoon. All thanks a lot, at me everything turned out, after execution of this command sudo cp -a * /mnt && sync - the system was launched and works without errors.
