I am trying to cross compile the samples found within the tegra-multimedia-api package. I have followed the instructions provided within README and CROSS_PLATFORM_SUPPORT files that were found within the tegra-multimedia-api package.
Following the instruction from README:
- Change directory to
$HOME/tegra_multimedia_api/samples
followed by:
make returns an error:
/bin/sh: 1: aarch64-unknown-linux-gnu-g++: not found
Hi NobodyHere,
By installing the samples via Jetpack, it is automatically compiled on TX2.
All Makefiles are for compiling on TX2, not cross compiling.
Within the tegra_multimedia_api/samples/Rules.mk file the following lines perform a test to determine if locally compiling or cross compiling:
ifeq ($(shell uname -m), aarch64)
CROSS_COMPILE :=
else
CROSS_COMPILE := aarch64-unknown-linux-gnu-
endif
By modifying lines as noted below, this issue can be resolved…
CROSS_COMPILE :=
else
CROSS_COMPILE := aarch64-linux-gnu-
endif
or even better, since above ignores users defining CROSS_COMPILE:
CROSS_COMPILE :=
else
ifeq ($(CROSS_COMPILE),)
endif
endif
Hi Michael,
WE will clean the codes making confusion and add note in documentary. Thanks for your comment.
